#16
Re: FRC T-bone-ing and Hexagonal drive
Citation Needed
#17
Agreed. Emery cloth? That would be... surprising if that passed inspection.
#18
Dear Enterprising Student, It's not a good idea. Sincerely, Every Other Team |
#20
The important thing to remember here is that a hexagonal frame perimeter is an ENHANCEMENT and not a necessity. Don't sacrifice build time to design a hexagonal drivetrain unless you think that t-bones are what's holding you back.
In my opinion, only the top ~5% of FRC teams can both benefit from a hexagonal drivetrain and have the resources to build one without sacrificing elsewhere on the robot. |
#21
The emery cloth thing was a mistake on my part. I heard the word tossed around a couple years back when I was a freshman. In retrospect, what I heard was probably a joke because I just did a little research and making emery cloth bumpers would be insane.
#24
It's...a lot more complicated than that. A drivetrain's ability to turn (assuming a skid steer AKA tank drive) is based upon the geometry of the wheels and how they contact the floor.
See this guide for a good summary of how different drivetrains behave in different scenarios: http://www.simbotics.org/files/pdf/drivetraindesign.pdf You might look under the Applying Principles section for bits about wheelbase and track width and stuff like that to answer your question, but the presentation as a whole is fairly comprehensive and very useful to someone just getting into drivetrain design (which I presume you are interested in) and exploring beyond the buy-a-kitbot-and-put-it-together level of mechanical and physical analysis. |
#27
Most teams shouldn't make this a priority. Putting, say, a week into a hexagonal drivetrain won't make your robot better than putting that same amount of time into the things you mount to your drivetrain. You've gotta walk before you can run. If you're already running, build a hexagonal drivetrain. |
#29
Can anyone elaborate on what exactly is happening with the plywood in the bumper in a robot like 1678 pictured above? Is it separate pieces cut and joined somehow?
#30
Their 2014 robot was even simpler than this year's robot IMO. Surgical tubing catapult, Vex ballshifters IIRC, dual intakes, and ball stabilizer. If somebody could get a closeup of the way they made the hex chassis, that would be interesting to see. |
