Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 08-12-2015, 18:42
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
[FTC]: [FTC]: Autonomous-run motor with encoders does not stop
We are trying write an autonomous program to drive the robot a specified distance. we have connected encoders to our 4 drive motors and here is the code we have so far :
public class CCAutonomous extends LinearOpMode {
    OpticalDistanceSensor opticalDistanceSensor;
    //Drive motors
    DcMotor motorFrontRight,motorFrontLeft, motorBackRight, motorBackLeft;
    @Override
    public void runOpMode() throws InterruptedException {
       // opticalDistanceSensor = hardwareMap.opticalDistanceSensor.get("sensor_ods");
        motorFrontRight = hardwareMap.dcMotor.get("front_right");
        motorFrontLeft = hardwareMap.dcMotor.get("front_left");
        motorBackRight = hardwareMap.dcMotor.get("back_right");
        motorBackLeft = hardwareMap.dcMotor.get("back_left");
        motorFrontLeft.setDirection(DcMotor.Direction.REVERSE);
        motorBackLeft.setDirection(DcMotor.Direction.REVERSE);
        motorFrontRight.setMode(DcMotorController.RunMode.RUN_USING_ENCODERS);
        motorFrontLeft.setMode(DcMotorController.RunMode.RUN_USING_ENCODERS);
        motorBackRight.setMode(DcMotorController.RunMode.RUN_USING_ENCODERS);
        motorBackLeft.setMode(DcMotorController.RunMode.RUN_USING_ENCODERS);
        waitForStart();
        // Reset enoders to zero
        motorFrontLeft.setMode(DcMotorController.RunMode.RESET_ENCODERS);
        motorFrontRight.setMode(DcMotorController.RunMode.RESET_ENCODERS);
        motorBackLeft.setMode(DcMotorController.RunMode.RESET_ENCODERS);
        motorBackRight.setMode(DcMotorController.RunMode.RESET_ENCODERS);
        waitOneFullHardwareCycle(); // We use these in attempt to gain stability.
        motorFrontLeft.setTargetPosition(2440);
        motorFrontRight.setTargetPosition(2440);
        motorBackLeft.setTargetPosition(2440);
        motorBackRight.setTargetPosition(2440);
        motorFrontRight.setMode(DcMotorController.RunMode.RUN_TO_POSITION);
        motorFrontLeft.setMode(DcMotorController.RunMode.RUN_TO_POSITION);
        motorBackRight.setMode(DcMotorController.RunMode.RUN_TO_POSITION);
        motorBackLeft.setMode(DcMotorController.RunMode.RUN_TO_POSITION);
        motorFrontLeft.setPower(-0.5);
        motorFrontRight.setPower(-0.5);
        motorBackLeft.setPower(-0.5);
        motorBackRight.setPower(-0.5);
        telemetry.addData("2 ", "motorFrontLeft:  " + String.format("%d", motorFrontLeft.getTargetPosition()));
        telemetry.addData("3 ", "motorFrontRight:  " + String.format("%d", motorFrontRight.getTargetPosition()));
        telemetry.addData("4 ", "motorBackLeft:  " + String.format("%d", motorBackLeft.getTargetPosition()));
        telemetry.addData("5 ", "motorBackRight:  " + String.format("%d", motorBackRight.getTargetPosition()));
With the power set to -0.5, the robot keeps moving and does not stop. How do we stop the robot after moving specified distance.
thanks
Charging Champions
Team 8660
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 13-12-2015, 22:12
whereisthemonke whereisthemonke is offline
FTC #4602
whereisthemonke is an unknown quantity at this point
Re: [FTC]: [FTC]: Autonomous-run motor with encoders does not stop
Hey, i would use the following code:
PHP Code:
//Drive motors
DcMotor motorFrontRight,motorFrontLeftmotorBackRightmotorBackLeft;
int leftFrontPosleftBackPosrightFrontPosrightBackPos;
Override
motorFrontRight hardwareMap.dcMotor.get("front_right");
motorFrontLeft hardwareMap.dcMotor.get("front_left");
motorBackRight hardwareMap.dcMotor.get("back_right");
motorBackLeft hardwareMap.dcMotor.get("back_left");
waitForStart();
leftFrontPos motorLeftFront.getCurrentPosition();
leftBackPos motorLeftBack.getCurrentPosition();
rightFrontPos motorFrontRight.getCurrentPosition();
rightBackPos motorBackRight.getCurrentPosition();
            while(
leftBackPos 2440 && leftFrontPos 2440 && rightBackPos 2440 && rightFrontPos 2440){
telemetry.addData("2 ""motorFrontLeft:  " String.format("%d"motorFrontLeft.getTargetPosition()));
telemetry.addData("3 ""motorFrontRight:  " String.format("%d"motorFrontRight.getTargetPosition()));
telemetry.addData("4 ""motorBackLeft:  " String.format("%d"motorBackLeft.getTargetPosition()));
telemetry.addData("5 ""motorBackRight:  " String.format("%d"motorBackRight.getTargetPosition()));
Use this code instead and tell me if it worked, I will use this code too if you confirm that it worked
Unread 14-12-2015, 15:12
We got around the original issue by setting the motor power to 0 after the Targetposition is reached. We also had an another issue with the condition performing the "and" condition on all 4 motors to check if the target position is reached. Two of the motors where always at zero position so we modified the condition to just check of the front set of wheels (which were the ones with the encoders returning the right values)
FTC Team #8660
