Go to Post The spirit of the game, and the game are essentially two different things. - ttldomination [more]
Unread 09-12-2015, 11:07
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Intake wheel motors
Originally Posted by sanddrag View Post
Anyone have any pictures of Mini-CIM intakes?
Our 2014 robot had a mini-cim intake (it's hiding under the duct tape).
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 09-12-2015, 11:25
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Originally Posted by JesseK View Post
How do we accurately and cleanly cut the CIM/MiniCIM output shaft down to 3/8"? We once made a prototype with a MiniCIM/Versaplanetary, but wound up using standoffs from the adapter because the kids weren't able to figure it out at the time.
Not exactly useful for every team because it requires a lathe but... we had an interesting solution.
We clamped down our CIM motor inside the lathe and then, instead of turning the lathe itself, we powered the motor directly from a battery. Lathes are not designed to be used on a shaft that's spinning quite that fast so it generated a lot of heat (make sure to oil it up). In the end it worked perfectly with the small caveat that the CIM shaft had burn marks on it.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 09-12-2015, 12:28
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The MiniCIM/CIM for Versaplanetary seems like a great way to go to get more power - except for a major factor (IMO). How do we accurately and cleanly cut the CIM/MiniCIM output shaft down to 3/8"? We once made a prototype with a MiniCIM/Versaplanetary, but wound up using standoffs from the adapter because the kids weren't able to figure it out at the time.
We wrap the CIM/MiniCIM in pool noodles then clamp it in our table vise. We use visegrips on the end of the shaft that is going to be cut off, then just hack saw through the shaft. We sand down the end to clean up any sharp edges after we are done.
Unread 09-12-2015, 12:40
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
We clamped the motor in a vise. Held the shaft with vice grips and cut off the shaft with a dremel. Cut as straight as possible. My student took his time but really just eyeballed it. He then jsut filed the edges to remove any burrs. Didn't have any issues with it last year.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 09-12-2015, 12:41
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
You can run the versa planetary without modifying the CIM output shaft. I talked with Aren at vexpro, and the original intent for the CIM adapter was to leave the shaft unmodified. I do not remember the reason for them suggesting the modified shaft for normal usage, but we ran mostly unmodified CIM shafts with the adapters as shown below.
You have to leave all the stages in the gearbox for shaft clearance. We did have to shave off the end of the output shaft around .010"-.020" with a file to remove a minor interference.
We had zero issues with the setup for the 2015 season.
Unread 09-12-2015, 12:51
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We've done this also, +1 for the recommendation because it works and it's fast.
Our 2014 Mini-CIM+VP intake can be seen in this picture; it is a straightforward rip-off of Team JVN's Build Blitz design.
Touch-it-own-it.
Richard Wallace
since 2003
Unread 09-12-2015, 13:31
Engineering Coach
We found that that can work but it comes with some caveats.
1. Some CIM motors have the keyseat cut at the back of the output shaft, this makes it near impossible to have any amount of key in the input coupler to transfer toque unless you cut the shaft down some.
2. It adds a lot of length to the whole assembly.
Unread 09-12-2015, 13:46
Jared Russell's Avatar
Taking a year (mostly) off
Originally Posted by Ginger Power View Post
Another tip for intake wheels when it comes to selecting the right gear ratio and motors: Your "intake velocity" aka the linear speed of your intake wheels should be greater than the max speed of your drivetrain. This makes it easier for you to intake a game piece while driving at it full speed.
As a huge fan of fast intakes on a team with a reputation for building fast intakes...
I've heard this rule of thumb parroted around a lot, but (in my experience) this can lead to teams building drastically undergeared intakes that stall at the first sign of trouble.
There is more that goes into a roller intake than speed, and high speed can bring with it some drawbacks. For most game objects that FIRST has given us, an effective intake requires carefully crafted geometry, materials selection, and deformation characteristics to work well. You may find that your mechanism is loaded in such a way during intaking that in order to prevent a stall when loaded AND run at a greater tip velocity than your maximum drive speed when unloaded would require a ludicrous amount of power. Or, you may find that a high tip velocity breaks static friction between the roller and game object when the robot isn't at full speed (i.e. most of the time).
It's really more of an impedance matching problem than a raw speed maximization problem (though adding more POWER to the equation usually helps). A lot of these tradeoffs are non-obvious and difficult to estimate from first principles, but can be the difference between a ridiculously effective and totally ineffective intake. Every team guesses wrong on total intake power and speed/torque from time to time. Unless you have the ability to quickly remake a custom transmission in-house, you really can't beat the VersaPlanetary for being able to quickly change your mind and adjust any or all of the power parameters of your mechanism.
Unread 09-12-2015, 14:46
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
When I think about fast robot intakes, nothing comes to mind more then FRC95's robot from 2002.
That being said, the RS775-18V will be greatly missed in the future for its size to power ratio. I'll all for throwing as much power as you can at an intake within the confines of weight and design. Looks like Mini-CIMs, BAGs, and 9015s for the future.
Unread 09-12-2015, 15:08
Deke's Avatar
no team (No Team)
You are correct. I forgot that we did have to sort through our CIM motors to find suitable keyseat flavors.
There were two reasons we didn't want to cut the shaft down.
1. To use the CIM motors for other applications later that required a normal output shaft.
2. With such a long assembly, we had a slightly improved side mounting with the input stage tapped holes kept in the assembly.
Unread 09-12-2015, 19:07
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Here is a video of their intake in action.
https://www.youtube.com/watch?v=jL6VtO5VSd8
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 11-12-2015, 20:06
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Thanks to everyone for all the suggestions. This has been very helpful.
Unread 13-12-2015, 22:19
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
95 in 2002 looks amazing. But so does this.
Unread 13-12-2015, 22:25
Looked at the date of this post... went "Oh, that was BEFORE VEX announced their new products". I'm now ducking and covering from the hail of RS775-18s flying my way as they're replaced by the VEX counterpart...
Unread 14-12-2015, 09:48
Chris is me's Avatar
AKA: Pinecone
At this point, seems like the best choices are between the BAG, the mini-CIM, or the 775Pro.
The BAG is great if you want a lighter motor, don't need a ton of power, but your intake might stall. It's also better if you're trying to watch your current draw as it draws less current than the mini-CIM or 775.
The 775 has a lot more power at a similar weight, so if you can spare the current and don't think the intake will ever stall, it's a great choice.
If you need both power and stall protection, and don't mind the weight penalty, than a mini-CIM is the way to go.
In any case, in this modern era of FRC there is simply no better choice than a VersaPlanetary for gearing an intake. The weight penalty is worth it in exchange for the extreme flexibility in gearing options. Your intake should definitely run through a VP, unless you're very sure of the gear ratio and you need every ounce of weight you can get.
