Go to Post Think like a criminal, and write the law to foil them! - Tristan Lall [more]
Unread 14-12-2015, 01:54
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
pic: 4183 Custom Machined Wheel
Unread 14-12-2015, 01:55
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: 4183 Custom Machined Wheel
How creative! Have you done any strength tests on it yet? How much does it weigh?
Unread 14-12-2015, 02:25
GUI GUI is offline
AKA: Gary
We haven't done any testing yet. According to my cheesy kitchen scale this one minus the hub and hardware is just over 120 grams, and there's a lot of room for cutting more material out.
Unread 14-12-2015, 03:15
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Looks good!
What are the dimensions of the wheel? I'm impressed with how light it is; a 4" HiGrip wheel from AndyMark is 140 grams, and this seems like it's of comparable (greater?) strength to the commonly used plastic wheels.
Unread 14-12-2015, 07:46
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Being a team that works with wood a tremendous amount, you probably know... but is a .5" hex sufficient for a wood drive wheel (even if it's only ~4" diameter)? I would think you'd at least want to make sure the interface didn't have slop.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 14-12-2015, 08:05
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
It sounds like the intent is to place a hub in these wheels.
Unread 14-12-2015, 08:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I believe this is the answer (emphasis mine):
Originally Posted by GUI View Post
It is designed to mount a VersaHub to interface with a 1/2" hex shaft, and the blue nitrile tread is attached with CA glue and staples.
As I read it, the hex hole in the wood isn't for torque transfer, but presumably for alignment.
Unread 14-12-2015, 11:56
FIRST Fan(atic)
Yep... good thing you guys can read! (unlike me) ;-)
Unread 14-12-2015, 12:29
Flywheel Police
Yep... good thing you guys can read! ;-)
Hey now! I can read perfectly fine!!!
Unread 14-12-2015, 13:05
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Looks cool! Can't tell if you have flange(s) to help hold tread in place, or perhaps you don't need it?
"A genius is just a talented person who does his homework" T. Edison
Unread 14-12-2015, 14:00
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
It's flanged on one side. I'd be interested in seeing how the glue holds up, it might be enough as is.
Also, if the flanged side is towards the inside of the robot, it should help handle the sideways load on the tread in the worst condition (being pushed sideways by another robot). Most of the load in that case is taken by the center wheel opposite the side that's being pushed. Maybe just one flange would be okay.
Unread 15-12-2015, 00:05
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Do you have an old operable robot base you can swap these onto and test them out? Not a bad idea for teams that lack machine shop capabilities.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 15-12-2015, 01:02
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
For BEST one year (Warp XX - 2012) we needed a large winch spool to wind up the cable we were climbing. I took the largest hole saws we had (3.5" and 3" I think) to some plywood and acquired 4 disks of wood of equal diameter and 2 larger disks for outer guards. I used a .25" pilot bit in the saw, so I aligned all 6 disks on a 1/4-20 all-thread with glue between each layer and clamped overnight. I then chucked the all-thread into the drill press using it as a lathe to sandpaper the edges smooth. It worked fantastically.
A few more steps and you could have basically this wheel on nothing more than a drill press. The hex broach is unlikely, so maybe a versa hub on both sides.
Unread 15-12-2015, 08:28
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you have a CNC shark router, you have at least some machine shop capabilities, no?
Unread 15-12-2015, 22:53
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Not at the moment. We may in the next couple of weeks and will for sure early in build season.
We actually have pretty substantial machining capabilities in-house: a Bridgeport mill, a lathe, the router and a Trotec Speedy 300 laser cutter. We use the laser whenever we can, since making parts with it is much faster than using the other tools.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
