Three Mini-CIMs in a gearbox?
What do you think the results would be if three minis were used in place of two CIMs in a drive train? I know about the speed/power differences. Has anyone tried it? A couple advantages I can think of would be:
Anyway, just curious what y'all think. |
Re: Three Mini-CIMs in a gearbox?
Requires more speed controllers, wire etc... |
If one min-icim has around 2/3 the power output of a normal cim, the why not just use 2 cims? I understand that the power output does not directly correlate to speed and torque, but you will start to see limits of the mini-cims before you see it on the cims.
Because of the extra motor controller required, and the increased cost/weight/complexity of a 3 motor gearbox, you would almost have to be in some sort of edge case in order to want to make this trade. That said, I can think of a number of those cases pretty easily:
I could see using mini-cims in a drive train in a game list Recycle Rush where you might want to use the cims somewhere else and don't need that extra power in your drivetrain.
We used a single mini CIM on each transmission last year give us more space for totes in our robots. The min CIMs gave us more distance between our transmissions, and saved us a little weight. The two mini CIM drivetrain was still sufficient to push our loaded robot around the carpet.
In addition, Vex has a fun little plot for the CIM and mini CIM motors on their website that shows a 3 minute peak power test. Looking at the two plots side-by-side, you can clearly see that the mini CIM has better peak power output characteristics (especially in the first 20 seconds of the test). http://motors.vex.com/cim-motor http://motors.vex.com/mini-cim-motor |
#7
Here's my current belief: depending on the requirements of the game, using three minis in place of two CIMs is a viable option. I'd still love to hear from someone who's actually tried it. Thanks for musing on this point, folks
#9
An interesting plot is to plot efficiency of the CIM vs miniCIM by time. Based on the Vex data, I think you will see the miniCIM is about 5% more efficient in the peak power test. When I ran a quick calculation, I assumed a 10.5V output for the CIM and 11V output for the miniCIM since the CIM pulls more current. Last edited by sastoller : 15-12-2015 at 15:47. |
#10
We ran zero CIMs on our 2015 robot. We drove our swerve with four Mini-CIMs and it drove just fine for last year's game. In a game like 08, I'd want about 8 Mini-CIMs.
#11
This paper compares some different CIM - mini-CIM drive combinations.
http://www.chiefdelphi.com/media/papers/3071 |
#12
Another noteworthy point is thermal mass
Those power/time graphs are really showing functions of internal temperature. As the motor heats up, its performance diminishes and even after a match it takes a while for recuperation. source and source 2 3 miniCIMs weigh more than 2 CIMs, and thus have greater thermal mass. If both systems were loaded equally (and the motors were equally efficient) the decreased loading/motor and therefore amps/motor of the miniCIMs should result in them running cooler. This is not important on a 1 match basis, but in an eliminations scenario, every degree counts. |
