Re: FRC shifting gears
Brought to you by the IACNAP campaign. |
Just like I don't claim to drive my engine up to the store... truck is a lot more appropriate. Last edited by MrBasse : 15-12-2015 at 06:45. Reason: Changed "little" to "lot" |
Actually the part applying the force is a rod or shaft. The rod is attached to a piston.
With the update to the servo rules this season, is there any change in the viability of using a servo to shift? Thinking of using a SonicShifter as a winch with about 20 lbs of force from surgical tubing when retracted. Don't know if it would be possible to shift with a 10-12W servo in that case.
Would appreciate help. Thanks. P.S. For those unaware, servos are now limited to the current put out by the 6V rail on the RoboRio instead of a strict Watt requirement as in previous years. |
This "IACNAP Campaign" is pretty annoying.
Linguistically, language evolves and usage is king, so what you want words to mean (and/or what you were taught that they mean, and/or what they originally meant (assuming you can even chase down the etymology to verify)) has no bearing whatsoever on what they currently mean. There is value in specificity, but there's also value in not "correcting" people when they're using terminology understood by everyone in the conversation. To whit, McMaster-Carr redirects searches for "pneumatic pistons" to their catalog page for "pneumatic cylinders." |
#7
I believe I saw in the Q&A that automotive motors like window motors but more importantly door lock actuators are legal. A door lock actuator could be a dandy device for shifting.
#8
I like that the actuation is linear in door lock motors but from the specs that I've seen (hard to find specs on them for some reason) it looks like they won't be enough. Maybe I haven't looked hard enough but the most I've found was capable of 8lbs of force... :/
#9
This one does 10 pounds. Last edited by Dale : 03-02-2016 at 20:53. |
#10
By the way, here's the Q&A that makes door lock actuators legal for the first time ever:
642 Q. Does an actuator with an included motor sold as a "door lock actuator" meet the definition of "Select Automotive Motors" per R29 (sample: http://www.amazon.com/dp/B0088YE6YQ/)? A. Yes. As per the answer to Q626 , the intent of "Select Automotive Motors" is to limit the selection criteria of automotive motors to those specifically listed in the parenthesis that immediately follows. "Door" motors are listed, and a motor sold as a "Door Lock Actuator" does fall under that category. |
#11
Our team chose to use servos with the Andymark sonic shifters however now we are looking into using pneumatic cylinders, however we'd also like to avoid adding another system if possible. Has anyone successfully or otherwise used door lock actuators such as this to shift?
#12
Or the difference between an engineer and smart engineer. |
#13
Clearly you don't have a force until you start having a differential pressure.Last edited by FrankJ : 03-02-2016 at 16:09. |
#14
The piston rod is transferring force from the piston head to the shifting mechanism.
