Go to Post Is any robot ever actually done? - BlondeNerd [more]
Unread 14-12-2015, 21:29
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC shifting gears
What do teams use to shift gears on gear boxes. Other motors? pneumatics?
Unread 14-12-2015, 21:36
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Re: FRC shifting gears
Our team uses pancake Pneumatic cylinders from vex pro. They work quite well, allowing the robot to shift fast and reliably but require a pneumatic system. They can be found here: http://www.vexrobotics.com/217-2778.html
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
This would be a great question to use the search tool here on cd. There are quite a few threads about this subject.
R.C.
MadTown Robotics Team 1323
Unread 14-12-2015, 21:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Pneumatic cylinders usually, and in the old days I believe servos were more common than they are now.
Unread 14-12-2015, 22:06
Other way around, actually. FRC-legal servos are WEAK. I'd tell you young'uns when my team tried that, but I'd feel really old... and we went with pneumatics because of the servo response (and AM had a handy conversion kit for their Gen2 Shifter).
Did you know that before 2005, every team got two shifting gearboxes in the KOP?*
The thing is that most shifting gearboxes take force to shift. Servos have a hard time providing enough force to actually shift. Ball-shifters, I think are the exception for that, and a 3-speed ballshifter could really use a servo's "infinite" positioning, but as a general rule a short-throw small-bore cylinder per gearbox (and per gear change in the gearbox) say about a 1" throw 3/4" diameter unit in the old days, is by far preferable. Pancake cylinders are more common now because they're smaller, lighter, and don't take as much air. Servos are sluggish, and tend to need to be ganged together to shift. Ain't worth it.
You could also use an electrical solenoid actuator, but the power limits on those are even more restrictive than on servos.
*Two drill motor transmissions, to go with the drill motors generally used for drive. Shifting took a little machining, creativity, and luck during matches, but it was present. Before my time the full drill was included...
Unread 14-12-2015, 22:13
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
What kind of force is needed? I saw a supershifter demo with a servo that put out around 9 lbs but it was no where near as snappy as the pistons.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 14-12-2015, 22:15
9 lbf is not a legal FRC servo. Unless it's insanely slow... servos are only 4W in FRC, and I find it very difficult to comprehend a 9 lb force out of a 4W servo. Also, factor in the load of a moving drivetrain.
60 psi on a 3/4" diameter cross-section seems to do the trick nicely.
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I just want to say how glad I am that First Newbie has been asking these questions. You'll go far by approaching problems this way. Way to go!
http://www.angelbotics.com
Remember why you're doing this.
Unread 14-12-2015, 22:17
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
"It's a cylinder, not a piston"
Brought to you by the IACNAP campaign.
Unread 14-12-2015, 22:18
jkelleyrtp's Avatar
AKA: Jon Kelley
Here is the shifter in question: http://www.andymark.com/product-p/am-2297.htm
Doesn't look like people like it very much, and I don't see a power rating on it.
Mechanical, CAD
Unread 14-12-2015, 22:23
IndySam's Avatar
If you call the good folks at AndyMark they will recommend you shift with air. FIRST legal servos (as of previous years rules) will have great difficulty shifting under load. I have seen teams use window motors to shift successfully but nothing beats the instant snap of a 3/4" cylinder.
You can get a lot of shifts out of a couple filled tanks.
Unread 14-12-2015, 22:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Most commonly pneumatics, though a few use servos, especially if the robot will not have any other pneumatic systems. AndyMark and VexPro shifters have pneumatic parts or kits referenced from their web pages, and AM also has servo kits. Due to the limits of servos allowed by recent FRC rules, servos do not provide as much force or speed in shifting, making pneumatics the favored method.
Unread 14-12-2015, 23:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
While you're correct that devices like these are pneumatic cylinders, the portion of the cylinder applying a force to shift gears would be a piston. What he said is not incorrect.
Unread 14-12-2015, 23:14
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
For video of it in action check this out.
461 Westside Boiler Invasion
45 Technokats
Unread 15-12-2015, 04:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
They're not even 4 W. (Servo manufacturers who publish ratings based on free speed × stall torque are falsifying or don't understand the power output of a DC brush motor.)
