Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 14-12-2015, 22:01
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC Gear Box thingy
What is the thing circled in red?
Unread 14-12-2015, 22:03
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
Re: FRC Gear Box thingy
Pancake pneumatic piston.
Used for shifting.
http://www.vexrobotics.com/vexpro/pn.../217-2778.html
Cortechs Robotics 2014-Present
Mechanical, CAD
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Pancake Cylinder.
"An error does not become a mistake until you refuse to correct it" ~JFK
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
That's a pancake Cylinder. It's used in 2+ speed gearboxes to shift gears on the fly.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 14-12-2015, 22:12
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Used for shifting.
Your link says Pancake Pneumatic Cylinder"
Brought to you by the IACNAP campaign.
"It's a cylinder, not a piston"
Unread 14-12-2015, 23:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The piston is the piece inside the cylinder which is pushed by the air and which in turn pushes and pulls the output shaft relative to the main cylinder body. P4s (pernickety persons' pet peeves) aside, the term piston is commonly used for the whole thing because it won't be confused with the shape of a pneumatic tank, compressor, motor, wheel, or shaft.
OBTW, if the one in the render above is a cylinder, we can also include any sort of extrusion as a cylinder by shape.
Unread 14-12-2015, 23:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you call it a pneumatic cylinder, it might remove some confusion
Unread 14-12-2015, 23:58
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I've had team members come back with air tanks (more commonly aluminum than plastic). We keep the tanks and actuators in different bins.
Unread 15-12-2015, 01:08
MrForbes's Avatar
AKA: Jim
Yup, that's why I said "might", rather than "will".
Unread 15-12-2015, 06:59
IndySam's Avatar
I don't know a single person in industry who would call it a piston. As mentors it's up to us to teach proper terminology.
Unread 15-12-2015, 07:28
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
IndySam is correct. If we are to prepare these students for working in the industry, we should teach (use) proper terminology. Incorrect, or non-standard, terminology leads to confusion and mistakes.
It is a cylinder or pneumatic actuator.
It can be used as a piston when attached to a cam but it is not a piston.
___________________
- Tennyson, Ulysses
Unread 15-12-2015, 08:33
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
And here I am calling them pneumatic actuators...
Unread 15-12-2015, 08:52
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We have had some engineering mentors call them pistons and we correct them at the same time. These are also mentors who never work with these types of components in their day jobs.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 15-12-2015, 09:50
MrForbes's Avatar
AKA: Jim
When I went shopping on FIRST Choice for our team, I selected several pneumatic cylinders, but no pistons.
The pneumatic cylinders each contain a piston, though
Unread 15-12-2015, 10:49
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
And I always assumed it was a British thing. They are always screwing up the English language over there.
