Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 15-12-2015, 08:19
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC pre made 2-speed gearboxes
What is the best pre-made (Andy mark or Vex Pro) 2-speed shifting gearbox?
Unread 15-12-2015, 09:26
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: FRC pre made 2-speed gearboxes
What have you found so far when you searched the forum?
Unread 15-12-2015, 09:56
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
What, in your opinion, is the best pre-made 2-speed gearbox? It would be helpful to discuss that, and what brought you to your decision.
Unread 15-12-2015, 11:06
Chris is me's Avatar
AKA: Pinecone
It's never what's best, it's what's best for your team / design.
That said, it's hard to beat the weight and quality of Vex's gears, so the choice basically comes down to ball shifter or WCP dog shifter. The dog shifter accomplishes a good reduction for a west coast drive in just two stages of gearing, and is best suited for direct drive output with chains to outer wheels. The ball shifters can both work with WCDs but all require 3 stages of gearing to direct drive a wheel. If you are doing a final chain / belt reduction between the gearbox and wheel, the ball shifter is the best choice. Finally, the ball shifter shifts more smoothly / easily than a dog shifter, but this is just a minor benefit in a drivetrain as both work well enough to be competitive.
