Go to Post The point of FIRST is to get a wide range of kids together and have them work as a TEAM. - Firewolf [more]
Unread 15-12-2015, 12:47
AdamHeard's Avatar
Lead Mentor
Re: FRC T-bone-ing and Hexagonal drive
Question (somewhat rhetorical): As it relates to being the victim of a T-bone pin, does swerve (or mecanum, or other omnidirectional drives) help you get out, or make the problem worse? What about if you're trying to place the T-bone?
In regards to swerve, we didn't do enough testing with this in mind to make scientific statements. That being said based on the three we've run, I would think it would make it easier to get out of T-bones in a perfect world. I'd highly recommend not investigating swerve as a t-bone solution. There are so many points in a swerve drive where the increased load from being t-boned could cause your gearing to experience increased friction and make the situation worse.
Our experience running butterfly in 2013 offseason made it seem well suited for that style of safe zone to safe zone sprinting, but we also ran a normal 6wd that year and had similar performance.
It's hard to say for sure, there are many variables involved with the implementation (and how its' driven) that matter a great deal, so it's not as simple as X drive versus Y drive.
The best thing to do is to proto and test what you want to run if this is a performance advantage you are going for. Designing your setup to be a modification of the AndyMark or Vex kit drives would make this iteration easier for most teams.
Unread 15-12-2015, 14:08
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Curious. What kind of butterfly did you run? This style? How did you have the controls set up? Were the front and rear wheels able to actuate independently?
Unread 15-12-2015, 14:24
FRC #1836 (MilkenKnights)
They ran the neutrino style with slightly faster gearing. Each module had it's own actuator and motor.
Unread 15-12-2015, 17:13
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Hexagonal and round robots have trouble fitting through doors in some venues. Williams Arena, I'm lookin' at you!
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
