Go to Post I don't know about the rest of you, but I do this to give kids an opportunity that I never had. - Jack Jones [more]
View Poll Results: What is your favorite feature of the SD540?
Light Weight 25 20.33%
Low Cost 47 38.21%
Multi-Bank Option 31 25.20%
I do not like this product. 47 38.21%
Multiple Choice Poll. Voters: 123. You may not vote on this poll
Unread 15-12-2015, 15:02
pnitin pnitin is offline
pnitin is infamous around these partspnitin is infamous around these parts
Re: SD540 Motor Controller
Originally Posted by Chris is me View Post
Will a firmware upgrade be released to remove the "safety feature" that cuts motor output if the input voltage drops below 9.5 volts? The "feature" is a deal breaker for me, as that is a surprisingly easy condition to reach on an FRC robot.
If you are letting down your battery 9.5 V your are basically killing your battery( actually 10.8V that is 1.8V per cell).
Lead-Acid battery will quickly built lead sulfide layers on plates ( no matter what is battery technology and what manufacturer claims)
you are basically screwing up battery and now it will have much high internal resistance so the you will start seeing voltage drop when you try to take out good amount of current.
