Go to Post You are beautiful. - Joe Johnson [more]
View Poll Results: What is your favorite feature of the SD540?
Light Weight 25 20.33%
Low Cost 47 38.21%
Multi-Bank Option 31 25.20%
I do not like this product. 47 38.21%
Multiple Choice Poll. Voters: 123. You may not vote on this poll
  #106   Spotlight this post!
Unread 15-12-2015, 15:18
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: SD540 Motor Controller
Originally Posted by geezloueez View Post
What is the lowest you have witnessed in a match?
I've seen my share of robots in brown out conditions. It's less severe these days than it used to be but it can still cause you some heartache at competitions. This is from one of the presentations on the control system last year:
And this is current (no pun intended) info about what happens and when:
http://wpilib.screenstepslive.com/s/...g-current-draw
EDIT: You can help prevent this by keeping happy batteries around and always keeping good ones in the robot.
  #107   Spotlight this post!
Unread 15-12-2015, 15:19
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
A temporary drop to 8V is a pretty common occurrence. I don't know what the absolute lowest is though. Current draw is going to be a very important thing to watch in the coming years.
The compressor turning on can drop the voltage a good 1-1.5V itself.
Edit: See Marshall's post.
  #108   Spotlight this post!
Knufire Knufire is offline
Originally Posted by asid61 View Post
Hence why batteries in FRC have such a low lifetime... Interesting tidbit.
We don't use batteries from 2011 or earlier. And we're probably going to start phasing out the 2012 batteries too. They start being unable to hold a significant charge.
We only use batteries in competition for a single year. After that they'll be used for practice for 2-4 years and then recycled.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #109   Spotlight this post!
Unread 15-12-2015, 15:20
Joining the 900 Meme Team
FRC #0079
<6V followed very closely by the robot stopping moving as the CRIO reset. Though occasionally we did see it spike that low and come back up.
  #110   Spotlight this post!
Unread 15-12-2015, 15:40
Jared Russell's Avatar
Taking a year (mostly) off
I am a first year mentor for a rookie team. May seem like a dumb question, but I have not been involved first hand in a match yet. What is causing the batteries to drop so low? Are you using old batteries?
Internal resistance is usually on the order of ~0.01 ohms for the sealed lead-acid batteries that we use.
If your battery is charged to, say, 12.7 volts and you are running 4 CIM motors at stall (= 4 * 131A = 524A current), you can expect a voltage drop of ~5.2V just due to battery resistance (in reality, there are other losses in wiring, connectors, and speed controllers as well, so treat this as an approximate). 12.7 - 5.2 = 7.5V.
This situation happens (instantaneously) any time you rapidly change direction assuming your wheels don't slip on the ground first. Once the drive is moving, your motors draw less and less current, and battery voltage quickly recovers.
You can imagine that a 6 CIM drive, or simultaneously driving while powering mechanisms or the compressor, will only make things worse. I have seen robots drop below 6V relatively frequently in other seasons. Design with care!
  #111   Spotlight this post!
Unread 15-12-2015, 15:41
pnitin pnitin is offline
pnitin is infamous around these partspnitin is infamous around these parts
Originally Posted by Chris is me View Post
Momentary drops to 9.5vs are not at all uncommon in FRC matches, depending on the number of motors on the machine, weight, traction, etc. It might not be great for batteries but I'd rather be able to drive for the rest of the match and potentially shorten a battery's life than not be able to drive to save a couple of bucks later on. Basically, I don't want the products I use to try and protect me from myself.
Actually what I am trying to say here is if you treat your battery well, it will serves you faithfully, if you abuse it, it will not serve you well. Momentary drops are called spikes and most of the filter will take care of it ( you will not see brown out for spikes) I think problem is when you want to start with 9V battery to begin with, you have problem.
That way CTRE chart is incorrect since no one ( sane person) will be turning on robot with 9V battery level in competition.
what you really want to see is how well they handles those spikes.
  #112   Spotlight this post!
Unread 15-12-2015, 15:47
Citation needed.
  #113   Spotlight this post!
Unread 15-12-2015, 16:19
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
https://xkcd.com/285/
  #114   Spotlight this post!
Unread 15-12-2015, 17:22
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
As an FTAA watching plenty of matches during competitions from close behind the drivers (anyone at events where I've FTAA'd can affirm that I move around a LOT), I see MANY driver station displays with the battery section flashing red throughout the match to indicate voltage momentarily dropping below thresholds. Not sure a match goes by that doesn't have at least 1 robot where we are watching for a brownout so that we can quickly inform the team why the robot isn't moving when they tell us they lost connection to the field. I try to inform the coach as the match is still going on so that they see it happening in realtime and not just get told after the fact so they know what to look for when trouble starts.
I also kind of make a habit of looking at the battery voltage readout on each DS as I pass them verifying connection to the field to get an idea of which bots might be in trouble in the case that I see a sub-12V reading on the display. Sub-11.5V (and barring being way behind schedule) and I ask them if they have another battery next to the field that can be quickly swapped.
Nate
  #115   Spotlight this post!
Unread 15-12-2015, 17:40
Here are a couple of real life examples to give you an idea of what you have to be prepared to manage in your power design.
Both Driver Station logs are from different teams that borrowed one of my laptops during competition.
Learn how to examine your own DS logs after a match. They are automatic and just brimming with useful data about how your robot performed.
Remember, too, that the power drawn during practice at home is tame compared to power drawn during a real match with competitors.
The yellow line shows the battery voltage for the duration of the match.
No roboRIO brownouts were experienced by either team during these logged events.
Both of these robots had good batteries.
These voltages are what the roboRIO and speed controllers directly experienced.
The first example is from a robot during an off-season event this past October with a large number of motors - drive, lift, tote grabbers all running.
The second example is also from an off-season event, but one held in November. It was a robot with four drive motors and one lift motor, and shows a lot less stress.
The biggest dips are when the motors are starting up from a complete stop, lifting a heavy load, or suddenly reversing.
These logs are taken from a game without active opposition. Expect much worse this coming season.
ID:	19568  Click image for larger version
  #116   Spotlight this post!
Unread 15-12-2015, 18:47
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
What filter are you referring to?
  #117   Spotlight this post!
Unread 15-12-2015, 20:04
Originally Posted by sastoller View Post
Since you guys seem to be SD540 experts in this thread, I was wondering if you could comment on the very high output resistance of the SD540 that was measured by CTR in their tests (surely you've seen the results). The voltage drop (power lost) in the motor controller is drastically worse than the competition? Did you guys make a design choice or tradeoff that resulted in this? Or is it possible that CTR just got a bad (or damaged) SD540?
And I'll also echo Chris's question regarding a FW update to modify the 9.5V brownout feature. Could you make this voltage threshold user adjustable in the future so that users could control which motor controllers shut off first? Would it be possible to add a throttling feature to reduce output to 50% when a certain voltage threshold is reached?
http://www.ctr-electronics.com/downl...please)?<br />
All FRC the controller on market use synchronous rectification,
they are not linear converter, so what is mentioned above is incorrect.
for example, consider your cellphone charger 115V In 5V Out @ 1A current,.
According to your theory it should dissipate 110W and should melt, but it does not. It dissipate much low power since it uses switching topology.
  #118   Spotlight this post!
Unread 15-12-2015, 20:25
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Are you trying to say that the SD540 looks at an average voltage reading rather than a instantaneous reading so current spikes would not cause it to brown out? Thus making a low voltage cut off to protect you from draining the battery below a 9v state of charge?
2016: FRC 865 Mentor
  #119   Spotlight this post!
Unread 15-12-2015, 20:26
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Incorrect.
The output is 5VDC@1A not the input. The input is closer to 115VAC@0.05A or ~6Watts (assuming 1W inefficiency which is actually high).
In a phone charger (or most other chargers/USB power supply sources) you have a AC to DC converter (most likely a bridge rectifier). Then you have a buck converter (probably a transformer) and a switcher boost (High speed MosFET, inductor, and shottkey diode).
___________________
- Tennyson, Ulysses
  #120   Spotlight this post!
Unread 15-12-2015, 20:56
Originally Posted by Daniel_LaFleur View Post
Incorrect.
Exactly ,
Same is applicable for motor driven by these motor controller, input current and output current are not identical due to switching and stored energy in motor inductance. so you can not just calculate power dissipation in switch by looking at difference in output voltage and output voltage and output current
