| View Poll Results: What is your favorite feature of the SD540? | |||
| Light Weight |
25 | 20.33% |
| Low Cost |
47 | 38.21% |
| Multi-Bank Option |
31 | 25.20% |
| I do not like this product. |
47 | 38.21% |
| Multiple Choice Poll. Voters: 123. You may not vote on this poll | |||
#106
Re: SD540 Motor Controller
I've seen my share of robots in brown out conditions. It's less severe these days than it used to be but it can still cause you some heartache at competitions. This is from one of the presentations on the control system last year:
![]() And this is current (no pun intended) info about what happens and when: http://wpilib.screenstepslive.com/s/...g-current-draw EDIT: You can help prevent this by keeping happy batteries around and always keeping good ones in the robot. |
#107
A temporary drop to 8V is a pretty common occurrence. I don't know what the absolute lowest is though. Current draw is going to be a very important thing to watch in the coming years.
The compressor turning on can drop the voltage a good 1-1.5V itself. Edit: See Marshall's post. Last edited by notmattlythgoe : 15-12-2015 at 15:21. |
#108
We only use batteries in competition for a single year. After that they'll be used for practice for 2-4 years and then recycled.
#109
<6V followed very closely by the robot stopping moving as the CRIO reset. Though occasionally we did see it spike that low and come back up.
#110
If your battery is charged to, say, 12.7 volts and you are running 4 CIM motors at stall (= 4 * 131A = 524A current), you can expect a voltage drop of ~5.2V just due to battery resistance (in reality, there are other losses in wiring, connectors, and speed controllers as well, so treat this as an approximate). 12.7 - 5.2 = 7.5V. This situation happens (instantaneously) any time you rapidly change direction assuming your wheels don't slip on the ground first. Once the drive is moving, your motors draw less and less current, and battery voltage quickly recovers. You can imagine that a 6 CIM drive, or simultaneously driving while powering mechanisms or the compressor, will only make things worse. I have seen robots drop below 6V relatively frequently in other seasons. Design with care! |
#111
That way CTRE chart is incorrect since no one ( sane person) will be turning on robot with 9V battery level in competition. what you really want to see is how well they handles those spikes. . |
#112
Citation needed.
#113
#114
As an FTAA watching plenty of matches during competitions from close behind the drivers (anyone at events where I've FTAA'd can affirm that I move around a LOT), I see MANY driver station displays with the battery section flashing red throughout the match to indicate voltage momentarily dropping below thresholds. Not sure a match goes by that doesn't have at least 1 robot where we are watching for a brownout so that we can quickly inform the team why the robot isn't moving when they tell us they lost connection to the field. I try to inform the coach as the match is still going on so that they see it happening in realtime and not just get told after the fact so they know what to look for when trouble starts.
I also kind of make a habit of looking at the battery voltage readout on each DS as I pass them verifying connection to the field to get an idea of which bots might be in trouble in the case that I see a sub-12V reading on the display. Sub-11.5V (and barring being way behind schedule) and I ask them if they have another battery next to the field that can be quickly swapped. |
#115
Both Driver Station logs are from different teams that borrowed one of my laptops during competition. Learn how to examine your own DS logs after a match. They are automatic and just brimming with useful data about how your robot performed. Remember, too, that the power drawn during practice at home is tame compared to power drawn during a real match with competitors. The yellow line shows the battery voltage for the duration of the match. No roboRIO brownouts were experienced by either team during these logged events. Both of these robots had good batteries. These voltages are what the roboRIO and speed controllers directly experienced. The first example is from a robot during an off-season event this past October with a large number of motors - drive, lift, tote grabbers all running. The second example is also from an off-season event, but one held in November. It was a robot with four drive motors and one lift motor, and shows a lot less stress. The biggest dips are when the motors are starting up from a complete stop, lifting a heavy load, or suddenly reversing. These logs are taken from a game without active opposition. Expect much worse this coming season. Last edited by Mark McLeod : 15-12-2015 at 18:55. |
#116
What filter are you referring to?
#117
they are not linear converter, so what is mentioned above is incorrect. for example, consider your cellphone charger 115V In 5V Out @ 1A current,. According to your theory it should dissipate 110W and should melt, but it does not. It dissipate much low power since it uses switching topology. |
#118
The output is 5VDC@1A not the input. The input is closer to 115VAC@0.05A or ~6Watts (assuming 1W inefficiency which is actually high). In a phone charger (or most other chargers/USB power supply sources) you have a AC to DC converter (most likely a bridge rectifier). Then you have a buck converter (probably a transformer) and a switcher boost (High speed MosFET, inductor, and shottkey diode). |
#120
Exactly , Same is applicable for motor driven by these motor controller, input current and output current are not identical due to switching and stored energy in motor inductance. so you can not just calculate power dissipation in switch by looking at difference in output voltage and output voltage and output current |
