Go to Post remember kids, never listen to Big Mike.... - Mike Schroeder [more]
Unread 15-12-2015, 19:17
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Read Battery Charger status from a device.
So I'm building a portable battery charging station for my team. A really cool idea I have, is mounting a old surface pro on the side, with the screen showing out that some how shows what percentage each battery on the charger is. Is there any device or system that I can use which reads the current battery status (while the battery is still plugged into the charger), and relays that information to a app on a external device. Such as a surface pro or tablet. etc.
Thanks in advace
Unread 15-12-2015, 19:31
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Read Battery Charger status from a device.
You can make a voltage reader for each battery port by splicing a voltmeter into the output wire of the charger. If you wanted to interface with a tablet, you would probably need some kind of microprocessor to compile the voltmeters' readings and send them over serial to the tablet. Or you could just use voltmeters with built-in LED displays.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 15-12-2015, 19:34
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
If I do that, won't i just get the voltage that the charger is outputting not the current voltage of the battery?
Unread 15-12-2015, 19:48
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
It will probably be something you have to make yourself.
I would check out the documentation on the Battery Beak
http://www.andymark.com/product-p/am-0995.htm
Unread 15-12-2015, 19:58
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
If I spliced in a voltmeter between the charger and the battery, would I get the reading of the output of the charger, or the Voltage on the battery?
Unread 15-12-2015, 20:05
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
If the charger is on, and charging the battery, you will get the voltage of the charger.
If it's an intelligent charger, then it will depend on the 'state' of the charger.
___________________
- Tennyson, Ulysses
Unread 15-12-2015, 20:07
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
If I'm using the frc charger (which is "smart" i believe : http://www.andymark.com/Battery-Char...-p/am-2026.htm)
would I just be reading the volts of the battery after the charger stops charging it?
Unread 15-12-2015, 20:14
Ari423's Avatar
FRC #5987 (Galaxia)
Oh, I forgot about that. Maybe you could send an output from the tablet through the microprocessor to a switch to turn off the power to the charger for a second every minute or so and take readings then?
Obviously full disclaimer: I have never done this before.
2013: Programmer
Unread 15-12-2015, 20:16
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Ya, maybe I can use a arduino and a relay, to turn it on and off. But I guess I also don't want to do that, because it would be interrupting the charge of all the other batteries on that charger. So that might get annoying. Don't know. Too bad the frc chargers don't have a serial output on them, lolz.
Unread 15-12-2015, 20:18
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Or is there maybe a way that you could measure if its full or not based on and amperage reading? Or would a amp reader also just show the amp output from the charger. It probably would. (in case you guys haven't realized yet, electricity isn't really my thing )
I could just use a volt reader like this : https://www.adafruit.com/products/460 but so no need for a tablet interface, but it wont be effective, since it would just show the volt output of the charger right?
Unread 15-12-2015, 20:32
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Reading the amperage between the charger and the battery will only give you the charging current, which is usually limited (purposely) by the charger (to either 2 or 6 amps).
To measure the battery appropriately you'd want to measure the internal resistance of the battery. This can only be done when not charging the battery (you actually need to draw current from the battery)
___________________
- Tennyson, Ulysses
Unread 15-12-2015, 20:41
Ari423's Avatar
FRC #5987 (Galaxia)
I can't say about the amps, but you could do some testing with a clip-on ammeter to see if there's a correlation.
I was thinking of using something like what you linked. Make sure whatever you use is rated high enough for the current these batteries can produce. Maybe mount a button next to the output displays that says "PUSH TO TAKE READING". The button would be wired to a relay to control the charger. Then the charging is only interrupted when you want a reading. The button would also need to switch on some kind of load. It wouldn't allow for continuous reading, but if that wasn't a feature you needed, it should be a fine way to go.
2013: Programmer
ceb515's Avatar
ceb515 ceb515 is offline
AKA: Charlie
FRC #2607 (Robovikings)
ceb515 is an unknown quantity at this point
Probably the easiest thing to do would be cracking open the case of the chargers, and soldering wires to both sides of the LED's, soldering the common ground and using digital inputs on an arduino to sense the LED state.
2015 - MAR Championship 3rd Place, Qualified for CMP
Blue Banners: 2010 Philadelphia Reigonal, 2014 Virginia Reigonal, 2015 Hatboro-Horsham, 2015 Upper Darby
SEE US AT THESE COMPETITONS:
Hatboro-Horsham District Event 2017, Seneca District Event 2017
Electrical Lead, Programmer, Designer, Pneumatics, Prototyping, All-Out-Geek
Unread 15-12-2015, 20:52
Ari423's Avatar
FRC #5987 (Galaxia)
That would be ok if you only want a boolean, charged or not charged. I assumed the OP wanted a numeric value of how charged the batteries are. Maybe I could be wrong.
2013: Programmer
Unread 15-12-2015, 21:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In order to know the "battery voltage" while actively charging, you will need to measure the charging current Ic as well as the terminal voltage Vt, and have a good idea of the "internal resistance" of the battery, Ri. Then, Vbatt ≈ Vt - IcRi. Ideally, you'd measure Ri
yourself, but if you just want a nominal value, a study by team 1640 a few years ago indicated that a good FRC battery has an internal resistance of about 0.02Ω. Alternately, if you use a 2A trickle charger, the difference would only be about 0.04V, even when still charging at full current.
