Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Unread 15-12-2015, 20:16
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Read Battery Charger status from a device.
Originally Posted by Ari423 View Post
Oh, I forgot about that. Maybe you could send an output from the tablet through the microprocessor to a switch to turn off the power to the charger for a second every minute or so and take readings then?
Obviously full disclaimer: I have never done this before.
Ya, maybe I can use a arduino and a relay, to turn it on and off. But I guess I also don't want to do that, because it would be interrupting the charge of all the other batteries on that charger. So that might get annoying. Don't know. Too bad the frc chargers don't have a serial output on them, lolz.
Unread 15-12-2015, 20:18
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Or is there maybe a way that you could measure if its full or not based on and amperage reading? Or would a amp reader also just show the amp output from the charger. It probably would. (in case you guys haven't realized yet, electricity isn't really my thing )
I could just use a volt reader like this : https://www.adafruit.com/products/460 but so no need for a tablet interface, but it wont be effective, since it would just show the volt output of the charger right?
Unread 15-12-2015, 20:32
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Reading the amperage between the charger and the battery will only give you the charging current, which is usually limited (purposely) by the charger (to either 2 or 6 amps).
To measure the battery appropriately you'd want to measure the internal resistance of the battery. This can only be done when not charging the battery (you actually need to draw current from the battery)
___________________
- Tennyson, Ulysses
Unread 15-12-2015, 20:41
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I can't say about the amps, but you could do some testing with a clip-on ammeter to see if there's a correlation.
I was thinking of using something like what you linked. Make sure whatever you use is rated high enough for the current these batteries can produce. Maybe mount a button next to the output displays that says "PUSH TO TAKE READING". The button would be wired to a relay to control the charger. Then the charging is only interrupted when you want a reading. The button would also need to switch on some kind of load. It wouldn't allow for continuous reading, but if that wasn't a feature you needed, it should be a fine way to go.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
