Go to Post "If I had a nickel for every time our robot actually worked, I'd have one whole nickel. It was fail. Epic fail." - lol, a team at the NYC FTC tourny - Akash Rastogi [more]
View Poll Results: What is your favorite feature of the SD540?
Light Weight 25 20.33%
Low Cost 47 38.21%
Multi-Bank Option 31 25.20%
I do not like this product. 47 38.21%
Multiple Choice Poll. Voters: 123. You may not vote on this poll
  #121   Spotlight this post!
Unread 15-12-2015, 21:52
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: SD540 Motor Controller
Originally Posted by pnitin View Post
Exactly ,
Same is applicable for motor driven by these motor controller, input current and output current are not identical due to switching and stored energy in motor inductance. so you can not just calculate power dissipation in switch by looking at difference in output voltage and output voltage and output current
Except in the case of CTRE's testing they were using power resistors instead of a motor (so no motor inductance), and commanding each motor controller to 100%. In that case, power output should equal power input minus losses in the controller.
  #122   Spotlight this post!
Unread 15-12-2015, 22:07
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Exactly ,
Are you by any chance affiliated with MindSensors or FRC 540? If so, it would definitely be worth mentioning-- then your comments aren't being taken as being from some random person on the internet, but instead as someone who actually has knowledge of how this controller was designed, which is something many of the people in this thread are interested in, and lends your statements more weight.
If you are just some random person on the internet, ignore me, this back and forth is vaguely interesting (as someone who has very little knowledge of electrical engineering).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #123   Spotlight this post!
Unread 16-12-2015, 05:05
pnitin pnitin is offline
pnitin is infamous around these partspnitin is infamous around these parts
To calculate power loss in any circuit, you have to look at power in minus power out this is correct, but power is V*I so you have to measure I_in and I_out not just I some random current.
  #124   Spotlight this post!
Unread 16-12-2015, 12:26
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Momentary drops are called spikes and most of the filter will take care of it ( you will not see brown out for spikes)
Do you know this to be true for the SD540? Please answer 'yes' or 'no'.
If the answer is 'yes' I think the SD540 will made a lot more sales. If the answer is 'no' then it is still up in the air because momentary drops below 9.5V are going to kill robots on the field.
  #125   Spotlight this post!
Unread 16-12-2015, 12:33
AdamHeard's Avatar
Lead Mentor
Why take the risk at this point?
There are so many proven controllers on the market, let other teams be the guinea pig this season.
Speed controllers especially are very high on the list of FRC components where no level of failure or odd behavior is tolerable to any team.
  #126   Spotlight this post!
Unread 16-12-2015, 12:50
sastoller sastoller is offline
FRC #2122 (Team Tators)
sastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to behold
It's a little different than a cell phone charger taking 110V AC input and 5V DC out...
For the conventional motor controller, you can make the assumption that Iin = Iout. Here's Why:
If you look at conventional motor controller designs, the current that drives the motor flows from the input of the motor controller, through a large output device (Power MOSFET or BJT), through the load (motor, or bank of resitors), and then back into the motor controller, through another large output device, and finally, back out the negative battery input on the motor controller.
You can think of the output devices in this case like a switch. When the output devices are "on" (transistors are in the saturation region), they have a small resistance (this is what causes the voltage drop between the input and output of the motor controller). This resistance here is in series with the load. Kirchhoff tells us that current through all components in the loop is the same. Operating on the assumption that the SD540 is in fact built like most conventional motor controllers, the input current will be the same as the output current (assume extra current consumed for control circuits etc in the motor controller is negligible). You know the resistance of the resistor bank, and you know the total power output, so you can easily calculate current through the motor controller. Now, knowing Iin and the delta V across the motor controller, you can calculate the amount of power consumed in the motor controller. This power is dissipated as heat.
As you can see, from the 50A load test on the MindSensors site, this motor controller does, in fact, get HOT (125C after 5 minutes at 50A), and still climbing... Seems to me like a lot of energy lost to heat in the SD540, not to mention a potential safety hazard...
http://www.mindsensors.com/content/7...haracteristics
2014 to present: Mentor on 2122
2008: Student on 2468
Maintain a healthy fear of what can go wrong
  #127   Spotlight this post!
Unread 16-12-2015, 12:59
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Stupid questions but the casings for the SD540 controllers seem to be 3D printed. What is the plastic they are printed with? Is it ABS? Doesn't ABS begin to melt around 110C or so?
  #128   Spotlight this post!
Unread 16-12-2015, 13:31
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
80-125 degrees C is the glass transition temperature for most variants of ABS. So it will start to get soft there but that doesn't mean the entire case will melt at all. If it was enough to liquefy the case then we wouldn't 3D print ABS at much higher temperature.
At worst it would likely melt the FDM layers together making it more a solid than it started.
I often print ABS over 225 degrees C and vacuum form over 150 degrees C.
To put that temperature in perspective your heated 3D print bed to keep that ABS from warping can be 110 degrees C.
So if the heated print bed isn't turning it into a puddle or ruining it...
  #129   Spotlight this post!
Unread 16-12-2015, 13:37
marshall's Avatar
Like I said, stupid questions... Thanks for explaining though.
  #130   Spotlight this post!
Unread 16-12-2015, 14:50
Not a stupid question at all . I had noticed this as well and wondered too.
  #131   Spotlight this post!
Unread 18-12-2015, 17:07
philso philso is offline
FRC #2587
Wow! Go on vacation and lots happens.
Exactly ,
No! A typical FRC motor controller will not have any significant energy storage elements in them so the input current is going to be pretty close to the output current. The difference between the input current and the output current is the current consumed by controller circuitry and should be insignificant at high motor currents. The motor's inductance does not have the effect you think it has.
Yes! Stop talking about cell phone chargers. The circuit topology is totally different and the energy transfer mechanisms are also totally different and are not comparable with what goes on in the motor controllers used in FRC.
Thanks CTRE for posting test results that are well documented and give the test conditions. I used the values to estimate the losses in each of the motor controller using the data from the 11.05 V input case.
Iout = Vout / 0.2 Ohm
Pcont = dV * Iout
Victor SP - 12.4 W
Talon SRX - 15.1 W
Spark - 21.8 W
SD540 - 44.3 W
The high voltage drop and high watt loss in the SD540 is consistent with the data that Mindsensors has published showing excessively high temperatures on their heat sink (125 degree C, and climbing).
Does anyone have an SD540 where they have opened it up, or are willing do so, and report what sort of MOSFET's are used in it?
  #132   Spotlight this post!
Unread 18-12-2015, 17:30
mindsensors.com mindsensors.com is offline
Rookie Year: 2015
mindsensors.com is an unknown quantity at this point
Thank you all for your feedback!
The SD540 is equipped with a battery safety feature that would disable operation when battery voltage drops below 9.5 Volts.
Based on your concerns we have realized that such a safety feature is not desired by the FRC community, so we have released a model that does not include this feature. The new SD540B will work down to 6 Volts without disabling any operations! Here is our voltage comparison chart:
http://www.mindsensors.com/content/7...540-and-sd540b
Since our design and production facility is local and our SD540s are made here in USA, we have the advantage to implement changes quickly. The new model SD540B is available now and ordering information is here: http://www.mindsensors.com/frc/159-sd540-model-b
  #133   Spotlight this post!
Unread 18-12-2015, 17:34
AdamHeard's Avatar
Lead Mentor
Can you comment on the appreciable efficiency difference? Will you be able to fix that as well before kickoff?
  #134   Spotlight this post!
Unread 18-12-2015, 17:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
regardless of anything else, making changes that quickly is pretty darn cool.
  #135   Spotlight this post!
Unread 19-12-2015, 00:30
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Which motor control microcontroller is buried in there?
Software Mentor
3853 Pridetronics[
