| View Poll Results: What is your favorite feature of the SD540? | |||
| Light Weight |
25 | 20.33% |
| Low Cost |
47 | 38.21% |
| Multi-Bank Option |
31 | 25.20% |
| I do not like this product. |
47 | 38.21% |
| Multiple Choice Poll. Voters: 123. You may not vote on this poll | |||
#121
Re: SD540 Motor Controller
If you are just some random person on the internet, ignore me, this back and forth is vaguely interesting (as someone who has very little knowledge of electrical engineering). |
#123
To calculate power loss in any circuit, you have to look at power in minus power out this is correct, but power is V*I so you have to measure I_in and I_out not just I some random current. |
#124
If the answer is 'yes' I think the SD540 will made a lot more sales. If the answer is 'no' then it is still up in the air because momentary drops below 9.5V are going to kill robots on the field. |
#125
There are so many proven controllers on the market, let other teams be the guinea pig this season. Speed controllers especially are very high on the list of FRC components where no level of failure or odd behavior is tolerable to any team. |
#126
It's a little different than a cell phone charger taking 110V AC input and 5V DC out...
For the conventional motor controller, you can make the assumption that Iin = Iout. Here's Why: If you look at conventional motor controller designs, the current that drives the motor flows from the input of the motor controller, through a large output device (Power MOSFET or BJT), through the load (motor, or bank of resitors), and then back into the motor controller, through another large output device, and finally, back out the negative battery input on the motor controller. You can think of the output devices in this case like a switch. When the output devices are "on" (transistors are in the saturation region), they have a small resistance (this is what causes the voltage drop between the input and output of the motor controller). This resistance here is in series with the load. Kirchhoff tells us that current through all components in the loop is the same. Operating on the assumption that the SD540 is in fact built like most conventional motor controllers, the input current will be the same as the output current (assume extra current consumed for control circuits etc in the motor controller is negligible). You know the resistance of the resistor bank, and you know the total power output, so you can easily calculate current through the motor controller. Now, knowing Iin and the delta V across the motor controller, you can calculate the amount of power consumed in the motor controller. This power is dissipated as heat. As you can see, from the 50A load test on the MindSensors site, this motor controller does, in fact, get HOT (125C after 5 minutes at 50A), and still climbing... Seems to me like a lot of energy lost to heat in the SD540, not to mention a potential safety hazard... http://www.mindsensors.com/content/7...haracteristics |
#127
At worst it would likely melt the FDM layers together making it more a solid than it started. I often print ABS over 225 degrees C and vacuum form over 150 degrees C. To put that temperature in perspective your heated 3D print bed to keep that ABS from warping can be 110 degrees C. So if the heated print bed isn't turning it into a puddle or ruining it... Last edited by techhelpbb : 16-12-2015 at 13:39. |
#129
. I had noticed this as well and wondered too. |
#131
Wow! Go on vacation and lots happens.
Thanks CTRE for posting test results that are well documented and give the test conditions. I used the values to estimate the losses in each of the motor controller using the data from the 11.05 V input case. Iout = Vout / 0.2 Ohm Pcont = dV * Iout Victor SP - 12.4 W Talon SRX - 15.1 W Spark - 21.8 W SD540 - 44.3 W The high voltage drop and high watt loss in the SD540 is consistent with the data that Mindsensors has published showing excessively high temperatures on their heat sink (125 degree C, and climbing). Does anyone have an SD540 where they have opened it up, or are willing do so, and report what sort of MOSFET's are used in it? |
#132
Thank you all for your feedback!
The SD540 is equipped with a battery safety feature that would disable operation when battery voltage drops below 9.5 Volts. Based on your concerns we have realized that such a safety feature is not desired by the FRC community, so we have released a model that does not include this feature. The new SD540B will work down to 6 Volts without disabling any operations! Here is our voltage comparison chart: http://www.mindsensors.com/content/7...540-and-sd540b Since our design and production facility is local and our SD540s are made here in USA, we have the advantage to implement changes quickly. The new model SD540B is available now and ordering information is here: http://www.mindsensors.com/frc/159-sd540-model-b |
#133
Which motor control microcontroller is buried in there?
