Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 17-12-2015, 05:36
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Smooth LED lighting
How do teams like 118 (2013) and 4488 (2014/2015) achieve relatively smooth lighting effects with LED lights, i.e. diffusing light so that individual LEDs are less discernible? Is this just a product of a neat hole pattern that obscures parts of the LEDs?
118 in 2013 for reference
4488 in 2015 for reference
2012 - 2015 • Team 2601
Unread 17-12-2015, 06:26
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Looks to me like they are behind a slightly frosted panel with LEDs on the top and bottom. Indirect led lighting is awesome.
Unread 17-12-2015, 07:41
EmileH's Avatar
EmileH EmileH is offline
uses the Talon SRX way too much
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Smooth LED lighting
They would put a strip of individually-addressable LEDs behind a frosted or matte panel, which would create the "blur" effect. I'd recommend a 60 or greater pixel-per-meter density for best effect. Pololu makes some good weatherproof LED strips.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 17-12-2015, 10:04
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Don't know for sure, but I always assumed they used a thin (like 1/16") white acrylic sheet as a diffuser.
http://team2168.org
Unread 29-12-2015, 13:52
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
I was talking with a member of 4488, the use this to diffuse their LEDs.
Unread 29-12-2015, 14:27
Volunteer, WPILib Contributor
no team (Waiting for 2021)
As said above, we use some thin diffuser paper taped to the inside of the rail behind the cutouts. The LED's are 60 led per meter NeoPixel strips, which are affixed along the inside of the rail for the entire length, which allows them to light both sides of the rails, which have cutouts.
Team 4488 - Mentor 2013-2016
Unread 29-12-2015, 15:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
How do you get them to sit evenly behind the rail? I would think that they would easily wrinkle or bend enough to distort the light.
Unread 29-12-2015, 16:00
The diffuser sheet is taped tight at the ends, with some small pieces of double sided tape in the middle at some of the cutouts to make sure it sits flat. And the lights are double sided tapes every foot or so along the lenght to make sure they sit flat. Plus far away you won't notice any distortion. We also run pneumatic and power wires up the same rails, and if you look up close you can see the shadows from them in the lights. However from more then 3 feet away its not noticeable.
Unread 29-12-2015, 16:35
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
https://www.superbrightleds.com/more...-housing/2039/
we used a rail with a snap in diffuser like this
2016 Central Illinois Winner. Curie Division finalist
