Go to Post It is a difficult balancing act - we're engineers because we like to solve problems, and to take a step back and let someone else solve it, with what may be a poorer solution, is darn hard. - DonRotolo [more]
Unread 17-12-2015, 11:21
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
FRC Team 1086 Legendairy Octocanum MK V
Team 1086 would proudly like to present its 2015 offseason project: Our LegenDairy Octocanum MK. V
Stats:
• 4CIMs + 4 MiniCIMs
• 4” Andymark Mecanum wheels
• 2” Hex Broached Colson wheels
• Mecanum Speed ≈ 16fps Free Speed, 14fps Actual
• Traction Speed ≈8fps Free Speed, 7fps Actual
Changes from MK III (Last Built Octocanum):
• 8 Motors
• In 4 Motor Configuration, lighter than MKIII
• Single Stage Reduction rather than Toughbox Nano
• Frame Pieces are laser cut .09
• Colson Modules are bent 1/8”
• Piston is now 2” stroke rather than 3”
• Bearings are press fit and Loctite-ed in
All questions or comments are welcome!
2014: IRI on a losing record.
Unread 17-12-2015, 11:42
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: FRC Team 1086 Legendairy Octocanum MK V
Best workshop carpet ever.
Hi!
Unread 17-12-2015, 11:43
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Looking good guys. How does it handle being hit from the side with the traction wheels down?
I need to come out and visit your shop at some point.
Unread 17-12-2015, 11:54
wilsonmw04's Avatar
Coach
Matt, You are welcome anytime.
To answer your other question: we haven't really tested that. It's something we can do, though. I'm not that concerned, however. If we were to be hit in that way pulling the tractions up and running on the mecanums should solve that issue. We used that maneuver to good effect in Aerial Assist.
Unread 17-12-2015, 12:02
Flywheel Police
There seems to be a decent amount of extra space between the frame rails and the modules themselves. One thing you could try is to put some delrin on either side of the modules and move the frame rails closer together to basically pinch the module between them. You'd then get horizontal support for the modules.
Hopefully we both make it to the DCMP so I can see it in person if the game calls for a drivetrain like this again.
Unread 17-12-2015, 12:16
Darkseer54's Avatar
AKA: Zach Kaplan
In addition to what Mr. Wilson said, we are planning to run more tests on it. We have not yet sideloaded it, but plan to do that and a few other tests, including running it with SD540s.
Unread 17-12-2015, 12:48
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
Awesome! I love your music choice, I knew I wouldn't be the only person to use Knife Party music in a robotics video! I also love the design, I think I'm gonna look into this being one of my team's off-season projects for 2016!
2014 Gateway Robotics Challenge Winners with 1985 and 2481
FRC IS LIFE
Robolions 3397 pages
facebook- https://www.facebook.com/robolions3397
youtube- https://www.youtube.com/user/robolions3397
Instagram- @robolions_3397, https://instagram.com/robolions_3397/
Unread 17-12-2015, 15:02
wilsonmw04's Avatar
Coach
We have restrained the modules with retaining rings. This will be the third year we have used them without a failure (as long as they were installed properly). We did this get away from spacers. Might rethink this if it's a really defensive game.
Unread 17-12-2015, 17:03
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I like hitting stuff btw
Unread 17-12-2015, 17:33
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
Looks really nice! Have you guys seen how well it can traverse obstacles like a scoring platform? I know it's unlikely that there will be an object EXACTLY like that, but it does look pretty close to the ground.
Unread 17-12-2015, 18:37
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Yep, pretty sure at the moment the frame is low enough that you could place a penny in front of it and push it around. We are evaluating a few options for raising it up.
Unread 17-12-2015, 19:18
Darkseer54's Avatar
AKA: Zach Kaplan
Thanks for the idea! Just tried that out, and at speed it could make it over, but moving slowly it gets stuck every time. I got a video of it with colsons down, but it can do it with mecanums down (it just gets stuck much more often.) As Alex said, we are contemplating a few different ways to raise the clearance. I will edit in the video when I get home.
EDIT: Here is one test. Here is another. Both of these videos are with traction wheels down. I didn't get video of it going over with mecanums, but it works, just less consistently.
Unread 17-12-2015, 20:35
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Just wondering: what is the ground clearance on that thing? I'm designing my own octocanum modules and I'm having trouble getting the ground clearance I want. Looking at these videos, what I have may be good enough.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 17-12-2015, 20:48
That was actually one of the things we were testing with this set up. Right now, you can write anywhere on the bottom of the frame with sharpie and it will get wiped off. We are sitting at about .24 of an inch (this is at the rivet). We do know we need to raise it because usually game elements have supports under the carpet that raise the carpet about a 1/4 of an inch.
Unread 17-12-2015, 20:55
Ari423's Avatar
FRC #5987 (Galaxia)
So I'll try to design mine with a little bit higher ground clearance. Thanks for the heads up.
2013: Programmer
