Go to Post After all of this is said and done, think about how much more you all will know about the lovely state of Montana and other things not related to robotics. :) - Madison [more]
Unread 17-12-2015, 15:56
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: [FTC]: Split Clamp vs Axle Hub
Originally Posted by F Elliott View Post
Rookie coach alert.
The Tetrix Split Clamp (W739078) and the Tetrix Axle Hub (W739172) seem to be two ways to achieve the same purpose.
I read somewhere when using the Split Clamp to only use two of the attachment holes so the clamping mechanism isn't restricted.
When should I use the clamp and when should I use the hub?
THANKS!
For Tetrix axles, I was not aware that a Tetrix Split Clamp (W739078) existed, and searching does not pull one up for me. Where did you order it? any link?
I found a PIC of it in thr FTC Inspector manual PDF, in the section on legal/illegal parts. They probably both initially hold axle grip at similar level, but the set screw is more prone to progressive loosening than the clamp. The significant amount of hub protrusion that the clamping "fingers" cause, demands that swing clearance around the hub must accommodate this considerably longer radial reach of the fingers beyond just the hub's OD.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
