Go to Post ...I've changed my position. I'm fully supportive of Joe's suggestion... - Chris Hibner [more]
Unread 12-17-2015, 08:15 PM
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Team 1658 flying inverse differential swerve Video+CAD files
As previously seen here: http://www.chiefdelphi.com/forums/sh...d.php?t=140181
Here is a video of a quick test run we did. We don't have full functionality yet but serves well for initial demonstration purposes of this system.
https://www.youtube.com/watch?v=WfxK...ature=youtu.be
Here are CAD(autodesk inventor) files of the system. I'm fairly confident all the parts and dimensions are accurate but as a disclaimer: Accuracy is not guaranteed.
https://drive.google.com/file/d/0B4f...ew?usp=sharing
Unread 12-17-2015, 09:11 PM
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Team 1658 flying inverse differential swerve Video+CAD files
I still love this idea. The well-controlled slow driving would have been helpful in 2015 to not knock over stacks when placing your stack. With some pretty basic (or not so basic if you choose) programming, you could make an 'auto-shifter' from differential mode at low joystick input values for better control to normal mode at higher joystick values for faster driving. One less thing to for the driver to worry about. I look forward to hearing more about this project!
BTW anyway we can get the CAD either in STEP format or on GrabCAD so Solidworks users can take a look?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 12-17-2015, 09:44 PM
FRC #1658
On the higher values differential mode is kind of like normal mode since the motors are driving in the same direction, just not same speed. But at full tilt they are the same so our high end is more or less identical.
As far as the CAD goes, I don't have inventor on my home pc so I wouldn't be able to do any conversion until after the season starts but pretty much all the CAD software packages have the ability to convert files from other formats so i'm sure you'll find a way to import the files into your cad package or at worst use an online converter.
Unread 12-17-2015, 10:29 PM
Ari423's Avatar
FRC #5987 (Galaxia)
Interesting, on the video it looked like it went faster in normal mode. Maybe the driver just wasn't pushing the stick as far on differential mode.
2013: Programmer
Unread 12-17-2015, 10:41 PM
FRC #1658
Ye it was the first time that driver picked up the controls. It can go both faster and slower in a more controller manor but he wasn't familiar enough with it yet to properly show what it's capable of doing. I had a bit more practice with it and could have showed off the various aspects a bit better for comparison but I had to do the recording so can't do both xD we attempted to have someone else record while I drove prior to this but i'm pretty sure that video would make a lot of people puke.... so I ended up having to take the video myself. Certainly not a shining achievement from what can be seen in this video but I kind of like that too so others don't get a full proper demonstration and while it can be seen working the finer details are left to their own imaginations =p Until competition that is then this system will shine in all it's glory xD (if we end up deciding to use it anyway) or they can attempt making one themselves to find out.
Unread 12-18-2015, 12:18 AM
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Can you guys tested pushing stuff with it yet?
Unread 12-18-2015, 12:25 AM
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Why are motors making so much noise even when it's not moving? Feels like a car on neutral
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-18-2015, 12:30 AM
FRC #1658
We did some small tests but no video of it. Nothing is properly setup(the robot is 80 lbs short so traction is very low, we're using clamps to hold some parts on, the chain doesn't have proper guides/tensioners, need more time to refine and implement more code, etc...) so there would be little point in even attempting it. This prototype was a proof of concept and it succeeded at that task for our needs. Real testing will be after we see what the game is to see if we want to continue on this route at which point we will attempt a competition rated prototype.
Unread 12-18-2015, 12:32 AM
FRC #1658
when it's not moving it doesn't make any noise. However when we go at low speeds in Differential mode then indeed it is a noisy machine. That's because the top motors are going full speed and the bottom motors are going nearly full speed the opposite direction. So there are a few parts spinning at very high speeds. That's kind of the whole point of the differential system, we can have high power at very low speeds.
Unread 12-18-2015, 01:02 AM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Have you thought about trying to optimize this so that the CIM is running at the RPM at which it has the highest power? Or does running them like you describe automatically result in that?
Unread 12-18-2015, 01:24 AM
FRC #1658
it all depends how you want to run the cims. There are various modes of operation which is one of the nice things about the design. We can certainly chose what reference speed the cims run at for varied effects such as most efficiency, or most available power(all out) or anything in between. We will certainly be playing with various methods but as far as which ones we end up using,who knows.
Unread 12-18-2015, 08:44 AM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Is it a correct statement that it is impossible to stall the top motor? If so it seems like it'd be a good candidate for a lighter and more efficient open-air motor (new 775, e.g.) so long it's geared correctly.
GitHub
Unread 12-18-2015, 09:32 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If the top motors are going "full speed" (which I read as free speed, or nearly so), they are generating no torque and thus producing no mechanical power. The bottom motors are going "nearly full speed", they are generating low torque, and are operating well down on the power curve. Where does this "high power" originate?
Unread 12-18-2015, 09:43 AM
I just want to double check, the transmission you are using is similar to this, correct?
Unread 12-18-2015, 01:32 PM
FRC #1658
you can still stall out the motors and while it would work to a degree the total capable speed and power is still reliant on both of the motors so if you used a 775 you will lose in both regards compared to a cim.
