Go to Post Your drivetrain might make my girlfriend break up with me :D - Tottanka [more]
Unread 18-12-2015, 18:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 610's Preseason Drive
Originally Posted by Avram Kachura View Post
Yes, it is held together by 1 threaded rod and 2 slots cut out on the CNC Mill
for alignment. http://imgur.com/a/ldUfC
Why was this piece made with the large flange? It appears to me that you could have used a smaller piece of stock and put all three holes inside the depression. With the belly pan installed, the large flange does not seem to be necessary to provide right-angle rigidity.
Also, when we used threaded rod to provide tension on a project a couple of years ago, we found it neater to use two bolts, two threaded coupling nuts, and a length of threaded rod a few inches shorter than the run, all of the same thread/pitch. This is less likely to snag on other parts, as there are no protruding bolt ends, just a hex head or socket cap.
Edit: This solution would obviously not work on your three-roll-pins-plus-rod method, but should do well with the rod running down the middle like this.
