Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
Unread 12-10-2015, 03:06 PM
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Preferences for Robot Through SmartDashboard
Hello,
My team is doing an offseason project and I've been playing around with the ability to set preferences for the robot through the SmartDashboard question. I haven't figured out a best place to retrieve those values yet (we use the Command Based robot, just incase that helps) and I was wondering if I could have multiple preference objects, probably one in each file we need a value. Is this something that will work? If so, will that mean that each time I create a preference object I need to have a different preferences window in the SmartDashboard?
Thanks,
Isaac
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
Unread 12-18-2015, 07:05 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Preferences for Robot Through SmartDashboard
Originally Posted by King Nerd III View Post
Hello,
Thanks,
Isaac
From what I understand, there is only one instance of Preferences which you can access through Preferences->GetInstance()
Why do you need multiple preference objects? You can add an arbitrary number of values to the single instance.
Unread 01-13-2016, 03:30 PM
AKA: Isaac
Sorry for the long pause in the posting here, but yes, I figured it out. I have to create an object in each subsystem to use it. So far the Preferences has been really nice to use.
Isaac
FRC Team 1410
