Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 18-01-2002, 18:00
AJ Howard's Avatar
AJ Howard AJ Howard is offline
AJ Howard is an unknown quantity at this point
Question Steel Edge
During the matches, may the steel edge of the goal rest on a non-moving(Relative to the robot) part of the robot?
Unread 18-01-2002, 18:52
Hubicki Hubicki is offline
#0007 (Team Firestorm)
Hubicki is an unknown quantity at this point
I believe the interpretation of the GM20.2 (Robot may not intentionally attach to the upper or lower plywood bases of the goals) really depends on the definition of 'attach'. If the contact with the plywood results in the abillity to control the goal, then it's definititely illegal. In your case, if resting the plywood on the robot restricts the goal's free movement, then I believe it's illegal. Sorry if that hinders some of your plans.
~Hubicki~
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
solid edge ver 12 ceileachair Inventor 1 19-01-2003 21:15
steel plate ........legal dimensions? archiver 2001 1 24-06-2002 00:32
leading edge of ramp? archiver 2000 3 23-06-2002 22:33
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
