Go to Post FIRST already has 494 Martians, plus 70 more. - GaryVoshol [more]
Unread 19-12-2015, 19:23
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Re: pic: Robo Riot 3418 practice robot
Originally Posted by GeeTwo View Post
Other than as a control board, is a belly pan really needed on an essentially triangular robot?
No, the belly pan is not needed for strength at all. We just use it to mount all of the electronics to. Everything is directly threaded to the lexan making it very easy to remove components.
We used 1/4 inch lexan with 4 10/32 screws on each side threaded directly to the frame rails. I am thinking that the side with the battery might be be quite strong enough but we will see after some demos.
