Go to Post Ask the right questions and you can get the right answers. - Chief Hedgehog [more]
Unread 18-12-2015, 23:41
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
pic: Robo Riot 3418 practice robot
Unread 18-12-2015, 23:44
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
It looks like you just need a belly pan and it is good to go!
Specs please.
Transmission used and ratio.
Drive formula (if not standard Kiwi).
Gyro?
Weight?
This looks like a well conceived design, I'm sure it you have learned a lot just by building it.
Unread 18-12-2015, 23:45
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Re: pic: Robo Riot 3418 practice robot
Looks to me like there's a Lexan bellypan.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 19-12-2015, 00:39
billbo911's Avatar
Now that I look at an expanded image, I believe you are correct. Either that or they have discovered the secrets of levitation!
Unread 19-12-2015, 03:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Other than as a control board, is a belly pan really needed on an essentially triangular robot?
Unread 19-12-2015, 19:21
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
We used the Andymark bane bot gearboxes for CIMs, 16:1 gear ratio. The frame with gearboxes and motors weighs 24 pound even. The mane frame is 1/8th wall 1 by 2 aluminum. We used 3/16 aluminum/steel rivets. Each side is 24.5 inches long.
Unread 19-12-2015, 19:23
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
No, the belly pan is not needed for strength at all. We just use it to mount all of the electronics to. Everything is directly threaded to the lexan making it very easy to remove components.
We used 1/4 inch lexan with 4 10/32 screws on each side threaded directly to the frame rails. I am thinking that the side with the battery might be be quite strong enough but we will see after some demos.
Unread 19-12-2015, 20:34
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Does putting the battery on one side make the robot drive crooked? We had problems last year on mecanum with uneven wheel loading. I imagine it would be similar if not worse on a kiwi drive.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 19-12-2015, 21:16
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
I havent really noticed anything weird. I have notice that it does not strafe very well no matter what.
Unread 19-12-2015, 21:44
Ari423's Avatar
FRC #5987 (Galaxia)
I wonder if you saet the battery over the center of the robot and tried driving if it would strafe better. When we added ballast to the opposite side of our robot last year to shift the CoM to the center it corrected all of our strafing problems.
2013: Programmer
Unread 19-12-2015, 22:38
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
That certainly is possible. However at this point it would be to much trouble.
Also the only service we have driven it on is a concrete floor. I am not really sure how it will handle on carpet.
Unread 20-12-2015, 08:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Assuming that you consider the battery to be at the back (or front) of the robot, that makes sense. Most of the weight is on the two "side" wheels, which point mostly forward/back, so you can get good forces in the forward/reverse direction. When trying to go sideways, half of the force should normally be coming from the "nose" wheel, but as it is carrying little weight, it cannot generate as much force.
As these wheels will have a higher CoF on carpet, I would expect better performance, including when strafing.
Unread 20-12-2015, 09:06
Ari423's Avatar
FRC #5987 (Galaxia)
Also since it looks like when that picture was taken the radio hadn't been fully mounted, you should try to move it away from that motor. Motors can cause electrostatic interference that messes with the WiFi signal. The further away your radio is from motors, large power wires, or spinning brushes (read static-y stuff) the better signal you'll get.
2013: Programmer
Unread 20-12-2015, 19:13
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
We will definitely do that at some point. In future preseasons we are going to be adding something on top,maybe something like a ball shooter of some sort. Then we will be able to mount the radio farther up at out of all the noise from the electronics.
