Go to Post I swear, at IRI, Gary and I only talked about coming up with a plan to do away with Billfred, we didn't actually do anything... yet... - MissInformation [more]
Unread 17-12-2015, 14:38
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Rookie Prototyping Materials
Originally Posted by Foster View Post
I was part of a team purge that got rid of all the Phillips, Robertson, Torx, straight blade, etc heads, wood, self tapping, etc. and replaced them with cap head bolts (and added some extra sets of T-handles) Restocked with a few diameters and multiple lengths. Seemed to work out well, only down side was when doing prototyping with wood parts needing to drill holes for fasteners. But hours saved not looking for matching screws or needing to use a Phillips on one screw and straight tip on the screw next to it was huge.
Standardizing on heads sounds like a great idea. Related to this is stocking multiples of key sizes of tools and not just buying a gigantic "one of everything" tool set. Sure you've got one of every possible socket or wrench in the giant set but three of your students are looking to use the same 7/16 socket to work with those standardized sizes and you've only got one...
Unread 17-12-2015, 20:44
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
2x4's and 2x3's should be your go to material for prototyping. A lot of the best teams use them for prototyping. Look at 254 in 2014. Also, vex hex shaft and thunderhex is good because it can drive most wheels for prototyping and a minor modification makes them able to be driven with a drill. Watch the recent game sense series on prototyping. Other good materials are the igus products. Super quick pivots and mock ups of arms can be made using igus.
Unread 18-12-2015, 09:28
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Watch some of the 973 RAMP videos on designing with sketches in CAD. One thing we've been known to do is print off full-scale drawing templates to trace for our prototypes and actual parts. Works great and gives the students an additional visual aid in addition to using traditional measuring tools.
The trick is to build your prototype to a high enough quality that will allow you to actually learn from it. A flimsy prototype that falls apart on its first use isn't a good prototype. Wood is a great material because you can keep drilling and adjusting things on the fly too.
For rookies, I'd highly recommend getting your AndyMark drive base assembled ASAP (have a few people start building it week 1, heck even day 1) and then attach your prototypes ontop of that frame to give you a more real-world test. Most teams use previous season drive base platforms but you most likely won't have that option.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 20-12-2015, 15:51
philso philso is offline
FRC #2587
Originally Posted by Weinberger View Post
Don't forget the prized prototyping material; the pizza box + duct tape.
We've used the cardboard lid of a pizza box to initially prototype a variety of items (both on the robot and for the playing field) because they're handy (accessible) and cheap (re-using)!
Good luck!
That is the alternate definition of CAD - Cardboard Aided Design
Unread 20-12-2015, 21:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If all you have for a drive base is that one KoP chassis, I recommend waiting until you have your overall robot design done, at least to the extent of knowing your horizontal dimensions, drive type, gearing/speed, and any interruptions that you will need in the frame (e.g. for game piece pick up). We did essentially as Ryan suggested above our first year (Rebound Rumble, a basketball-based game), and seriously compromised our chassis' integrity when we added a gap to pick up balls.
It's probably obvious to you as you've done this before, but for rookie teams especially: Decide before you start building something whether it is a prototype or will be the competition part (subject to later modification, of course). If it's going to be a competition part, you'll want to do a more careful material selection and construction than if it is just a prototype to provide dimensions and such for the real mechanism. With a prototype, you can stretch dimensions and weight that you know you will have to tuck in when you build for real.
Unread 20-12-2015, 22:30
Guess I should have specified - get your kit chassis assembled initially in the default configuration. Don't go modifying it significantly until you are fairly confident in the dimensions and functionality of your prototypes. Cutting a big chunk out of your frame without knowing how the rest of your robot will compensate for that is not a good idea.
The KOP chassis is usually made to be modified fairly easily so assembling in the default state and testing ontop of that as early as possible is still a great idea in my opinion.
Unread 20-12-2015, 22:42
Also, bear in mind that some areas will have Kitbot build days. As in, as many teams that think they'll need help with that show up at one spot with the parts and leave with it functional. If there's one near you, go to that one.
