Go to Post I still believe that if we are legitimately trying to make FRC be recognized as a real sport, then the GDC must treat it like one. - Jim Zondag [more]
Unread 21-12-2015, 00:43
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Modified super shifter gear box
Unread 21-12-2015, 00:46
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: Modified super shifter gear box
Do you by chance have any CAD models of this that you wouldn't mind sharing? I'm very curious to see how you assembled the internals of it. This is probably one of the narrowest inline gearboxes I've ever seen.
Unread 21-12-2015, 01:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I too would like to see something (even a photo) that shows how the bevel gears are set up. Did you use the AM-2621 bevel gear on the motor? If so, how did you adapt the .375 bore to the 8mm motor shaft?
Unread 21-12-2015, 08:11
joeweber's Avatar
Coach team 1322
I replaced the original first stage gear with the beveled gear. They both have a hex shaft. I did have to lathe the last stage gear to give clearance for the wheels. I do not have CAD drawings yet. Still waiting on the students. The beveled gears are easy to find on the Andy mark web site.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 21-12-2015, 08:19
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
It would be really cool to see this as a drop module.
Unread 21-12-2015, 09:04
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is super cool. I'd love to see more pictures of the bevel gears interface.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 21-12-2015, 11:51
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Great work! Just wondering, what was the motivation for using bevel gears? Was it to save space for electronics inside the robot, or was there some other reason?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 21-12-2015, 12:25
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
A bevel gear set creates a thrust load on each of the shafts -- motor and driven gear. This load is opposed by bearings of some type, causing a component of friction that is not present with the original spur gears.
This extra friction increases current draw and therefore reduces power available at the wheels when current is limited, as it will be by circuit breakers and by motor heating. Current draw with no wheel loading (fully assembled drive train with wheels-up; i.e., chassis on jack stands) is a good indicator of how much friction has been added.
A CIM with nothing attached to its shaft will draw about 2.5 Ampere from a 12V source while spinning "freely" at about 5300 rev/min. A CIM back-driving a second CIM (with its terminals disconnected) will therefore draw about 5 Ampere. A well designed, correctly assembled, and properly lubricated 2-CIM single reduction gearbox adds about 2 Ampere to this "free" current draw. Extra stages add a bit more, but the adder is less because the extra stages are not moving as fast. So, as an initial health check, I like to see free current less than 8 Ampere when testing a new spur-gear drive train.
Do you have free current measurements for this set up?
Richard Wallace
since 2003
Unread 21-12-2015, 14:25
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Thanks for sharing. We recently tested one side of a new drive train and measured about 7.5 amps. At the time I wasn't sure if this was reasonable. Your 8 amp rule of thumb makes sense!
Unread 21-12-2015, 15:31
What kind of drive train? Any bevels or worms in it, or just spurs and sprockets/pulleys?
edit: is it this one?
Richard Wallace
since 2003
Unread 21-12-2015, 16:29
FRC #0610 (Coyotes)
Yes, that was the drive train I measured the current on. I expect the current draw to go down once it has been driven a while and things loosen up. The chains are pretty tight because we added 0.018 to the center distance.
