Go to Post Not only would it be cool but the mental image of Dave's suffering when he writes a message in unintelligible characters makes me grin uncontrollably. - Andrew Schreiber [more]
Unread 21-12-2015, 10:28
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
WCP DS Encoders
My team is working on a versachassis drivetrain using the WCP DS gearboxes. We bought all the parts and are assembling them, however, we are not sure exactly how to mount encoders. Our team does have a lathe so it would be possible to tap out one of our axles and add a 1/4" shaft with a custom encoder mount... but we would rather not create a custom mount. Has anyone here ever used WCP DS with encoders?
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 21-12-2015, 11:53
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: WCP DS Encoders
The standard practice with a WCD is to simply cut a 1/4in hole into one of your drive axles and press an encoder into it.
Here is a picture: http://media.team254.com/2013/02/280705b8-DSC_0257.jpg
Unread 21-12-2015, 12:28
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: WCP DS Encoders
You could check out this post here. I would also check out the thread itself.
Unread 22-12-2015, 06:33
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: WCP DS Encoders
The WCP DS is not designed to mount an encoder, as for shifting gearboxes this will cause complications when writing code to calculate distance travelled etc. However, there is a very nice 3D printed part which should allow you to do this. It utilises the CUI encoders that were available in FIRST choice this year.
http://www.chiefdelphi.com/forums/sh...13#post1502113
For a WCD the most common thing, is either drilling a hole in an axle shaft and using a grayhill encoder. But it can have alignment related issues. The other method, is turning the shaft down on the lathe to a rod, the same diameter as the encoder shaft, and joining them with a flexible shaft coupling or just a piece of KOP surgical tube( backlash is not a major problem).
You could also try to use the new CTR mag encoders.
http://www.ctr-electronics.com/senso...c-encoder.html
