Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
Unread 17-12-2015, 00:09
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: pic: 4183 Custom Machined Wheel
188 has had a lot of experience and success with wood wheels on FRC drivetrains. Most were turned on a wood lathe, no CNC, DROs etc. They tended to be dead-axle with sprockets bolted directly to the wheel. I don't think they've ever needed to put flanges on the wheels to keep the tread in place, but I'm sure that will help. They do securely rivet or screw the tread on to the wheel. Special care is needed for the rivets at the end of the tread. It's hard to explain, but they put two rivets at the ends, but cut notches into the ends so that a half-width of the start of the tread sits beside a half-width of the end of the tread, and the ends "overlap" (not on top of each other, but beside each other). The two rivets go right beside each other, one into the start of the tread, one into the end, in the middle of the overlap. Very clean, and prevents any gaps in the tread - there's at least half-width at the gap.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 21-12-2015, 00:21
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Version 2 of the wheel. Improvements include:
-Reduced machining time from ~30 min to ~15 min with better toolpath generation and faster feed rate
-Reduced weight to 38 g vs 71 g for the original wheel (some of the variation may be due to different materials)
-Smaller diameter match 4" Vex Pro Traction Wheels
-Recessed hub keeps hardware from protruding past the wheel.
We haven't yet been able to test them on a chassis.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 21-12-2015, 13:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Very interesting! I'm curious how the hub goes on though; do you drill holes after putting it in for the screws or do you just glue it in and forgo screws altogether?
Unread 21-12-2015, 13:25
Aren Siekmeier's Avatar
on walkabout
I'm guessing they attach it with wood screws.
