Re: T-Shirt Cannon
]There have been a number of T-shirt cannon threads in recent years; you can find plenty with some searches, including ideas for rolling t-shirts and working through various problems. Here are a few key items:
Re: T-Shirt Cannon
Scuba tanks? 2500-3500 psi. Please tell me that's not what you're using.
Re: T-Shirt Cannon
I would assume their working pressure is much, much lower than that. There are several other teams that have used Scuba tanks in the past without any issues.
Re: T-Shirt Cannon
I would avoid a "custom pressure block" and just go for 100psi (or whatever you're running at) metal pressure fittings. Your barrel should also be thin-wall metal rather than thick-wall plastic.
Scuba tanks for storage sounds pretty standard from what I've seen here; just make sure you run a regulator to the output. ![]() What is the small cylinder in the back of the barrel for? I really like your design, it looks very neat. You could remove the twist axis if you wanted to to add stiffness (just turn the robot instead) but your way could be more interesting. |
Re: T-Shirt Cannon
That appears to be the firing mechanism. We used the same design for our cannon. It pushes the cartridge forward and activates the release of stored pressure at the same time. This also provides a good deal of safety with our cannon because it cannot fire over the pressure that is used to push the cartridge forward. In our case that pressure is 30 PSI, I don't see a lot of others running that low of pressure however.
Re: T-Shirt Cannon
Haha, I hope the twist will be interesting in a good way. As for the pressure block, I just couldn't think of a solution to transfer air from standard piping to the firing tube. Do you have any suggestions? I figured a properly welded on block of steel would suffice at 50 psi. (Please correct me if I'm wrong) |
#7
Re: T-Shirt Cannon
Oh wow, a T-shirt cannon that's not the usual "gathling" type. One thing that concerns me is the rod that the cannon system is mounted on. Was there a reason for such a mounting system?
My reasoning is behind... I believe Newton's Third Law: With an action force comes a reaction force. As cannon fires the shirt, the shirt "fires" back with the same force to the cannon. Therefore after several shots out of the cannon, that rod its mounted on will bend significantly. So yeah, I would strongly advise to mount the cannon onto something sturdier to stop this from happening. |
#8
Re: T-Shirt Cannon
Re: T-Shirt Cannon
Are you using one tank as the HP side and the other one for the accumulator tank to provide the volume of air at LP to fire the shirt? If so you will not want to use the valve in the LP tank to gain the volume of air flow. You can use 3/4"
steel pipe with NPT threads. A typical scuba regulator will drop the HP pressure down to about 170psi and I would suggest an additional regulator that is adjustable and will drop the pressure again to 150 psi max. You can view ours at prhsrobotics.com under outreach. It is built on the same principle that you are using. |
#10
Re: T-Shirt Cannon
Edit: Not a bit surprising after the teaser video; I made a bit of chain mail myself in the 80's. I'm rather impressed with how much our student leadership team is focussing on game mechanics, strategy, and grand strategy while ignoring the stylistic hints we've been given. I wish I could ignore teasers and game hints as well as they can. Last edited by GeeTwo : 22-12-2015 at 21:41. |
#11
Re: T-Shirt Cannon
We use a 2-1/2" nominal (2.465" ID) copper pipe as our barrel. Tee shirts have to be carefully rolled and are still tight. It takes about 30 PSI to pop them out. Normal demos we shoot at 40-60 psi. We go up to 110 psi on the football field. We are a little unique in that we use a shooting accumulator that discharges completely on every shot rather than feeding the cannon directly off the storage tank.
You want your hose between the barrel and the air accumulator as big and short as possible. That will limit the cannon's range of motion. I would mount the fire valve on the cannon to keep the flow in the hose as high as possible. Tapping pipe threads in a block of steel is doable. Especially with working pressures less than 120 psi. 3/4 pipe is getting on the big side for hand taps though. |
#12
Re: T-Shirt Cannon
Here's the result of our offseason project:
We have 4 fixed 3" barrels, all plumbed to a single manifold. The manifold has 3 Clippard tanks plumbed into it, giving approximately 100 cubic inches per shot. Each barrel is plumbed to the manifold through a fairly pricey 1/2" air piloted valve, salvaged from a piece of production equipment slated for disposal at our main sponsor. The manifold is recharged between shots via the compressor and a 2 gallon tank. Manifold refill takes 1.5 to 2 seconds. The ball valves shown are used to precharge the tank and/or manifold with shop air to lessen the load on the compressor (30% duty cycle). Short shots take about 40-50 psi and a full 100 psi charge results in distances of about 90 feet, depending on rolling skill. We use a short section of the barrel material to check the roll, looking for a slight interference fit. |
#13
Re: T-Shirt Cannon
Edit: This draws more current than the air piloted valve, I am sure. We drive ours through a 12V relay module, though a spike relay could serve the function, if you don't mind driving brads with a 3 pound hammer. (not that exact module, but a similar one with four ports) Last edited by GeeTwo : 23-12-2015 at 19:25. |
#14
Re: T-Shirt Cannon
[quote=GeeTwo;1514515]If your Clippard tanks use the usual FRC fitting, those three 1/4" diameter fittings are the limiting factor on getting air to the shirts quickly. If you used a section of galvanized pipe as a tank, with reducers at the end to feed a 3/4" or 1" valve, you could achieve the same launches with much lower pressure and probably less air. 3/4" normally closed valves are available for about $20, and I recall seeing 1" NC valves for less than the 5 port solenoids usually used in FRC.
Thanks for the input. Since this was being built from mostly scavenged parts, and didn't have to be FRC legal, we prototyped a single cannon with the 1/2" valves we had available and a commercially available (small) manifold with 4 Clippard tanks attached. Initial trials were uninspiring. Your point about cross-sectional flow area is well taken, as when we opened up the ports on the Clippard tanks to 3/8"NPT, we were shooting about 90 feet at 100psi. We were even able to maintain that distance with just 3 accumulator tanks, so that's where the design is now. We also replaced some tube fittings between the manifold with a 1/2" close nipple to improve flow. Down the road, we'll see about replacing one of the Clippard tanks with a smaller one and see if we can maintain a similar (or at least acceptable) max distance. Can't wait for January 9th! |
#15
Re: T-Shirt Cannon
Yes, from quick tests, it seems as though 50 psi (working) would be adequate to launch t-shirts.
