Go to Post I was very concerned about this thread. Then I realized you were talking about a computer. - Taylor [more]
Unread 21-12-2015, 13:45
suttonrc suttonrc is offline
FRC #3799 (Electric Fire)
suttonrc is infamous around these parts
pic: Mecanum 8 inch Iso
Unread 21-12-2015, 13:49
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: pic: Mecanum 8 inch Iso
I like the design and I applaud your team's efforts to have some set designs ready for kick-off. Just remember you have to redesign the whole set-up after kick-off for it to be legal.
Just wanted to point out that when using Mecanum, you want to have an even weight distribution across all 4 wheels. It looks like most of your robot's weight is on the back wheels. This will cause your robot to strafe improperly (as if it were rotating around it's front). You can use a gyro to compensate for this rotation, but evenly spreading your weight is probably the easiest way to go.
Other than that, good job! I love all the designs you've put up.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 21-12-2015, 13:57
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Originally Posted by LeelandS View Post
...Just remember you have to redesign the whole set-up after kick-off for it to be legal...
Really? I don't remember that rule. Aside from any rule changes from year to year, I was under the impression that you could reuse chassis designs year after year after year if you want to. Many teams (esp. those that don't CAD their chassis) use the same chassis design each year because they're familiar with it.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 21-12-2015, 14:00
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
You may want to recheck that...
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 21-12-2015, 14:05
Knufire Knufire is online now
AFAIK, reusing the CAD would be illegal. I have reCADed nearly identical drive systems during build sesaon to maintain legality.
On the other hand, if the CAD is published and available to the entire community, it's legal.
See R13 from the 2015 Game Manual:
Software and mechanical/electrical designs created before Kickoff are only permitted if the source files (complete information
sufficient to produce the design) are available publicly prior to Kickoff.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 21-12-2015, 14:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If I recall correctly, the 2014 bumper rules required that the bumpers be backed/supported by the frame every so many inches (8?). I don't see any frame backing down the sides apart from the corners.
Unread 21-12-2015, 16:02
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
If you post the CAD files online before kickoff you should be okay. I think I remember an annual flood of CAD designs being posted in the two weeks before kickoff in order to keep the legality.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 21-12-2015, 17:02
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
There's also a flood of syncs to teams' Github and other software source code control accounts during this period for the same reason -- sync up!
Unread 21-12-2015, 23:50
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Note that we currently don't know what, if any, parts/design reuse rules are in the 2016 Game Manual.
Unread 22-12-2015, 09:13
Good point. I left it open (in each design) as the bumper rules are a bit different from year to year. Depending on this year’s rules I could potentially mount stand offs on the side, between the rear wheel and the front motor, also potentially sideways within the chain loop or if necessary I could move everything in and put a full length member (or plate) on each side, but I would prefer not to if the rules allow it.
I hope to have the CAD posted sometime tomorrow. Am I correct in thinking that Google Drive is the standard way of doing that?
As shown the drive base would definitely strife an arc. In the past though the mechanism, and game pieces (that we typically locate on the front) tends to involve a good amount of structure, motors, gearboxes etc. I'm thinking, picking up totes, climbing 3 rungs of a pyramid, shooting basketballs and a robotic arm to pick up inner tubes. They were all centrally located more or less in the front of the robot. The rear weight bias is intentional as in the past we've had issues falling over forward due to being too nose heavy after adding our upper structure.
Unread 22-12-2015, 09:27
Ari423's Avatar
FRC #5987 (Galaxia)
NO. Please post CAD files on GrabCAD so people with any (or no) CAD software can look at it without downloading huge files. Also, if you get in the habit of using GrabCAD Workbench, it automatically does version control and file sharing for you.
2013: Programmer
Unread 23-12-2015, 17:55
Below are links to the CAD files.
https://grabcad.com/library/mecanum-8in-wheels-1
https://grabcad.com/library/mecanum-4in-wheels-1
https://grabcad.com/library/skid-steer-2-speed-1
https://grabcad.com/library/skid-steer-1-speed-1
Unread 23-12-2015, 20:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
You can't be ready for every possible rule change, but that's no excuse for not being ready for rules that we expect to be carried from one year to the next with no change. I can't see the GDC deciding that designs posted publicly can be used by every team except the team that posted them; there's no exit strategy from those pitchforks.
