Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 12-21-2015, 10:43 PM
Yanglin501st's Avatar
Yanglin501st Yanglin501st is offline
AKA: Yang Lin
FRC #3044 (OxBe4)
Yanglin501st is an unknown quantity at this point
Re: Problem with WPI Library
Originally Posted by euhlmann View Post
Try rebuilding the C++ Index. Right click on your project > index > rebuild
^I tried rebuilding the C++ Index like you said and nothing changed.
Originally Posted by ozrien View Post
Also I'm not sure that is valid C++ (unless C++11 allows constructor params to be specified like that now and I didn't know).
Try to follow the example in the Talon SRX Software Reference manual section 3.4.
http://www.ctr-electronics.com/contr...ical_resources
...and since you are using CANTalons, you probably should look through the manual for help and examples.
^I went through the reference manual and tried to mimic the example code provided. As a result, it fixed the current error but I now have yellow squiggly underline under a part of my code and I'm not sure what it means.
class Robot: public IterativeRobot
	CANTalon motor;
	Joystick joy;
	LiveWindow *lw;
public:
	Robot () : motor(1),
			joy(1)
	void RobotInit()
		lw = LiveWindow::GetInstance();
	void TeleopPeriodic()
		double leftAxis = joy.GetY(Joystick::kLeftHand);
		motor.Set(leftAxis);
	void TestPeriodic()
		lw->Run();
This was what it displayed:
"Multiple markers at this line
- Line breakpoint: Robot.cpp [line: 8]
- Member 'lw' was not initialized in this
constructor"
Thanks for the help so far, I've only programmed Java for a year and I'm still trying to understand C++ for this year's robot!
