Go to Post I may be right or wrong but I’ll be happily senile doing it. - ebarker [more]
Unread 14-12-2015, 16:07
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
12V power supply for roborio
Has anyone ever powered a roboio (or cRio) using a plug-in 12 volt power supply? I was thinking that it would be convenient to power it that way instead of using the battery/PDP when testing out code to drive sensors, arduino, etc (anything with low current requirements).
I picture the 12 volt supply feeding directly into the PDB, or possibly right to the roborio (although that would bypass any over-voltage protection provided by the PDP).
Unread 14-12-2015, 16:24
Re: 12V power supply for roborio
I use a 12v 2A wallwart directly into my roboRIO (but I'm not trying to run anything else). The only protection the PDP provides is a fuse.
Unread 14-12-2015, 16:28
We regularly power a robot control system with a 12v linear power supply. The one I have wired to an SB50 connector is capable of only a few amps, so we can't run any motors, but everything else works okay.
(Trying to use a switching power supply on the older PDB, with its own internal switching power supplies, was not a consistent success.)
Unread 14-12-2015, 19:33
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I've also used a 12v, 2A supply directly wired into the roboRIO. Something like this.
Also have used an old ATX computer power supply with the cRIO and roboRIO with no issues.
http://team2168.org
Unread 14-12-2015, 20:04
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
In a pinch I used a CAN Connector to connect a 12V wall supply to andersons, and have been using it ever since [hey it works for power too ]
I suppose I could have grabbed a RIO connector instead.
Unread 14-12-2015, 22:20
FRC #1493
Smile Re: 12V power supply for roborio
Thanks for all the feedback - I feel more comfortable going forward. This will be a convenience as we are trying to step up our use of sensors and automation this year.
Unread 22-12-2015, 01:41
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
In past years we've used the power adapter included with the D-Link radios as a power source for cRIOs/RoboRIOs.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 22-12-2015, 06:08
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
IIRC the D-Link took 5V and the cRIO took 12-24V. That doesn't sound like a good combination. Do I remember incorrectly?
We have a 12V power supply we use to test both the cRIO/roboRIO for programming and the entire robot if we are doing long bench tests and don't want to have to keep switching batteries.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2016, 14:38
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
I'm thinking about getting one of these for our benchbot
http://www.ebay.com/itm/100-AMP-CONT...EAAOSwBahVA8Ar
Supposedly 12 100 AMP - Put the normal connector on it (Anderson? ) and use it through the pdp just like it was a battery. I'm thking 100 AMP would be enough even to power 2 CIM's if they have no load on them right?
Unread 08-01-2016, 17:29
Ari423's Avatar
FRC #5987 (Galaxia)
According to Andymark, a CIM motor's free current is 2.7 amps. That is if it has absolutely no load on it. 100 amps will be more than enough to power 2 CIM motors at free speed. The problem comes when you attach them to gearboxes and wheels. I'd still say with a properly geared gearbox that you're pretty safe doing a 2 CIM drive off a 100 amp power source.
2013: Programmer
