Go to Post Teams that TRY to win and TRY to do their best end up having students that learn more, learn the value of hard work, and are inspired by the process. - Chris Hibner [more]
Unread 22-12-2015, 06:33
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: WCP DS Encoders
The WCP DS is not designed to mount an encoder, as for shifting gearboxes this will cause complications when writing code to calculate distance travelled etc. However, there is a very nice 3D printed part which should allow you to do this. It utilises the CUI encoders that were available in FIRST choice this year.
http://www.chiefdelphi.com/forums/sh...13#post1502113
For a WCD the most common thing, is either drilling a hole in an axle shaft and using a grayhill encoder. But it can have alignment related issues. The other method, is turning the shaft down on the lathe to a rod, the same diameter as the encoder shaft, and joining them with a flexible shaft coupling or just a piece of KOP surgical tube( backlash is not a major problem).
You could also try to use the new CTR mag encoders.
http://www.ctr-electronics.com/senso...c-encoder.html
