Re: 610's Preseason Drive
I hadn't considered buckling, so I took a stab at the numbers. I estimate the buckling load thusly (ignoring the pocketing of the tube because I'm not able to do it with FEA at this time): Fixed-fixed: n=4 I=0.034 in^4 (2x1x1/16) E=1E7 psi (aluminum) L=24 in F=23000 lbs Let's err on the side of maximizing preload. Even a very fancy grade 8 1/4-20 bolt is listed as having a clamping force of 2860lbs, so it's about an order of magnitude away from buckling under the preload alone. Granted, this doesn't say much about sensitivity to side loads. It's been a few years since I've broken out the calculations for side loads to trigger buckling, so I'd be very interested if you can estimate that under these simplified parameters. I'll happily concede buckling is a concern with a slender, compressively loaded member, but I don't think 610's preseason chassis is near that state yet. Again, this ignores the pocketing, which'll of course weaken things, but is a separate design choice. For preload to reduce bending: It seems sensible to me that preloading the tube axially, to ensure a compressive stress state, prevents a tensile component and thus reduces the risk of a bending failure. The shear stress increases, but again, I think it's within what the aluminum can handle. As it's statically indeterminate, I'm not sure how to crunch the numbers without setting up a simulation. Finally, to look a bit further into the source you provided (Step 10): Quote:
Yeah, sorry. |
