Go to Post I hope that 50 years from now, FIRST is no longer required. - Lil' Lavery [more]
Unread 22-12-2015, 15:49
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: pic: Octocanum Module
Originally Posted by GeeTwo View Post
You shouldn't need 2" - Bimba does have 1.5" cylinders in both square and round pancake styles. Remember that force goes up as the square of the diameter, so 1.5" provides twice the force of a 1.0625" cylinder (to within 1%).
I knew I didn't need a 2" cylinder, but it was the smallest I was able to find that would work when I posted. But speak and it shall be so. I went back and checked, and this time I found the 1.5" pancake cylinder. I will probably end up using that one.
You could pivot on the mecanum, which would make the cantilevered wheel the traction wheel which has a 42 tooth sprocket, if I did my math correctly. This would be easy to mount sprocket to wheel on a dead axle. This solution would also require a change in gear ratio of your gearbox - in the direction that it will probably get simpler and lighter. This would also make high-speed mecanum your "default" drive if the pressure goes out, which may be a good or bad thing depending on your game strategy/style.
One of the big perks of octocanum for me is built-in mecanum suspension. I wanted to pivot on the traction wheel so we wouldn't have to worry about uneven loading. I agree that switching them would make it easy to do a dead axle, but that would take away a major advantage in my opinion. Would it be advantageous to add more bolts, a piece of churro, or some other cross brace between the wheels to better connect the plates instead of going to dead axle?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
