Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 22-12-2015, 17:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: A small pneumatics spreadsheet
Neat stuff! A few suggestions that pop out at me:
  • The air volumes are huge! The first sheet has a 12 cubic foot tank - that's almost 90 gallons, or bigger than some whole FRC robots. Typical cylinders used in FRC range from about .0005 cubic feet (3/4" diameter, 2 inch stroke to 0.065 cubic feet (2" diameter, 36" stroke).
  • It would be great if the cylinder volumes were calculated from diameter and stroke (and possibly diameter of the shaft for the return stroke). Whenever feasible, spreadsheet or other UI inputs should be numbers available on the manufacturer's data, without requiring a lot of user pre-calculation.
  • For small cylinders and long tubing, the length of tube from the solenoid valve to the cylinder should enter into this. It doesn't do any work, but it does use up air.
  • For the versions with the compressor, are you assuming that the compressor will run continuously through the match? This is usually not a good idea. I also need to go back to see if your spreadsheet "turns off the compressor" when at full pressure. If you incorporate this, you should add the pressure at which the switch goes on as well as off.
Unread 22-12-2015, 18:39
WorldShaper WorldShaper is offline
AKA: B-G
FRC #2826 (Wave Robotics)
WorldShaper is an unknown quantity at this point
Thanks for the feedback GeeTwo!
The air volumes in the original copy were just there from me playing around with it to see what would happen. Integers were just a lot easier to type than small fractions and everything is nearly proportional, so they were nice test numbers for me.
Well now that you say that, its totally obvious. I've edited the original post to contain a spreadsheet that does just that, using Power Factor (Bimba's name for surface area, who knows why) and stroke length.
While the old sheet assumed that you had taken the volume of the tubing into account (or were at least comfortable with ignoring it), the new sheet has the option to include a specific quantity for it, based on the tubing's inner diameter and the length of tubing.
The middle complexity sheet only assess air balance, and so never shuts off the compressor. The assumption therein is that t=0 is the first actuation and that the pressure never returns to the maximum storage pressure, which at least in my team's history, is par for a match. That said, the more complex sheet does shut off the compressor when the maximum storage pressure is attained.
Cheers!
Unread 22-12-2015, 20:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Always a pleasure to help someone trying to help! Especially someone applying physics knowledge! (My BS and MS are in physics).
So's the wheel, but no one seemed to use it much until a very few thousand years ago. I didn't invent this rule of user interface, just passing it along.
As I'm sure you know, the force produced by a piston extending is (ignoring friction) F=Pa, where P is pressure and a is the area. Most typically in the US F is in lbf and P in psi, so the natural unit for a is square inches. Force Factor would be a more accurate name for a, but I'm speculating that the marketing folks at Bimba thought Power Factor sounds more impressive (and inaccuracy aside, I concur). The bottom line is that publishing the "Power Factor" and even making it a central element of the part number makes it easy for engineers (including amateurs, hobbyists, and FRC teams) to figure out what diameter piston their actuator should have.
Unread 27-12-2015, 10:41
ScandallB225's Avatar
ScandallB225 ScandallB225 is offline
AKA: Randall Bryan
FRC #0225 (TechFire Robotics of York, PA)
ScandallB225 will become famous soon enoughScandallB225 will become famous soon enough
Talking Re: A small pneumatics spreadsheet
Great information.
From my limited experience, the shaft volume is not insignificant for most FRC applications. We have found that the smaller the cylinder the more significant it becomes.
Again from limited experience, over the past two years we have trimmed weight to maximize onboard storage and still run below 60 psi with the compressor running full time.
The two years prior the compressor was on for short bursts at a time. So, both situations are good to have accounted for.
Did I mention, thank you for tabulating this for us?
Unread 27-12-2015, 13:55
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The quantity referenced was not the shaft volume, but the tubing between the solenoid valve and the cylinder.
In 2013 Ultimate Ascent, we used air during the main part of autonomous only to trigger our launcher (less than 10 cu in of 60 psi air per cycle); our climb was about 60% pneumatics and 40% electric powered. If we started with full tanks (7 clippards at approx 120psi), in match-duration drills we usually wound up starting the compressor as we lifted the robot half-off the floor. I suspect we used even less air during the matches due to defenses slowing us down.
Hear, hear!
