Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 22-12-2015, 19:00
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
pic: Recycle Rush Re-design
EDIT: The CAD to this model can be found here under the folder "REC-102": https://workbench.grabcad.com/workbe...WAlStxFm6c3ypj
Unread 22-12-2015, 19:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Recycle Rush Re-design
What power is in the elevator? In the drivetrain?
Why BAGs for the grabbers over 775s or something similar?
What size wheels are those? Can it go over the step?
You look like you're going over the height limit in the picture due to the can stabilizer elevator, not sure if I'm just seeing that wrong.
The only thing I would add to this would be some way to stabilize the stack as you move, as right now it looks like it could topple fairly easily with a quick turn.
Unread 22-12-2015, 19:11
AKA: Daniel Koh
Team Role: CAD
-4 CIMs are going to drive, and 2 RS-775s are going to the elevator at 1:10 reduction
-Wheels are 6in diameter, but I haven't tested with the scoring platform. I could probably add an idler wheel in the middle or something like that
-One of my friends on the team actually pointed this out that I might be going over the height limit. I measured the height to be dangerously close to 78in, but I think if I shorten the arm bars 1 or 2 inches it should be fine.
-I never thought of a stack stabilizer before... perhaps I can utilize the box tubing that the intakes are mounted on?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 22-12-2015, 19:17
AKA: Daniel Koh
Team Role: CAD
Oh right, as for BAGs vs RS-775s for the can burglars, I think it was motor stall that motivated me for BAGs over 775s, although now I'm kind of wondering why I chose BAGs in the first place
-KohKoh
Unread 22-12-2015, 20:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Why handle burglars? The window for lining these up is much smaller than for lid burglars. I just went to check an RC that I happen to have here at the house (yes, yes I do). The lid hole is at least five times as large as either handle, and it seems that a slight over/under reach is not nearly as likely to push the RC off the step onto the other side of the field. With "question mark" shaped arms, teams were able to reach the top holes over the landfill without violating the height restrictions.
Unread 22-12-2015, 21:01
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
You can still stall the 775pro. You just can't do it at max voltage for very long. Look at the data here: http://motors.vex.com/775pro
R.C.
MadTown Robotics Team 1323
Unread 22-12-2015, 21:38
Chris is me's Avatar
AKA: Pinecone
The window to hit is smaller, but the arm can be shorter with this technique, which results in a lighter arm that can theoretically be moved faster. There is also no contest for the grabbing location if you go for the handle versus the top of the lid. It's a design tradeoff that doesn't necessarily have a right or wrong answer - very successful teams used both methods to burgle cans on Einstein.
Unread 22-12-2015, 22:08
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Actually at a certain point the weight of the arm doesn't matter at all. Or you end up snapping it by going too fast
Unread 22-12-2015, 22:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
To optimize a shorter arm, the pivot should be much higher. With the pivot near the floor as shown, the difference is minimal or negative, especially if you insist on a linear arm for the grabber.
While there may be no contest for engagement with the RC, there is still certainly a contest for control of the RC if it has been grabbed by an opponent either above or aside before you pull it off the step.
Unread 22-12-2015, 22:49
AKA: Daniel Koh
Team Role: CAD
971's offseason robot had can grabbers made of carbon fiber, and they go decently fast. It's kinda similar to my can grabbers, so I wouldn't worry as much about snapping.
If I wanted to aim for the opening in the lid, how would one physically make that sort of geometry? It's not like one can bend carbon fiber to meet its needs (or can you?). Would the solution here be to use like 1x1 box tubing with the appropriate angle brackets? Or is there some better solution?
-KohKoh
Unread 22-12-2015, 23:27
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
PVC pipe or aluminum tube with carbon fiber rods. Bent sheet metal would probably work although I never made bin grabbers out of it myself.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 22-12-2015, 23:56
AKA: Daniel Koh
Team Role: CAD
Originally Posted by Max Boord View Post
PVC pipe or aluminum tube with carbon fiber rods. Bent sheet metal would probably work although ive never made them myself.
I believe that 649 doesn't have access to sheet metal resources. As for PVC, I'm a bit concerned. Two weeks ago, I made swords out of that material for a Hamlet skit, and one person dropped it, and it broke into three pieces. It could've been the fact that it had holes cut in them, but I would feel safer using something more reliable
-KohKoh
Unread 23-12-2015, 00:30
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I have seen videos of 971 doing their own carbon fiber layup. It seems tedious, so you could just use 3d printed or custom made endcaps for regular CF tubes and just stick the hook on the end like that.
Unread 23-12-2015, 02:13
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Nice job!
About picking up the can.
- Is there a 2nd elevator section hiding behind the stack?
- How does the robot grab the bottom of the can?
(elevator pivot or another mechanism)
Dave
Unread 23-12-2015, 02:48
AKA: Daniel Koh
Team Role: CAD
Originally Posted by DaveL View Post
Nice job!
Dave
Nope, there's only one elevator, and that's exclusive to stacking. Also, the elevator is really short: it can lift up to the second tote level; after all, stacking really only occurs at that level.
To answer the second question, the robot has a four-bar linkage arm powered by 2 BAG motors (okay is there like a thread about BAGs vs. 775s somewhere?). That lowers down and actuates a pneumatic claw to grab the bin. I do not need a pivot for the claw, because the geometry of the four-bar automatically controls the angle of the claw to be horizontal with the ground.
-KohKoh
