Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Unread 22-12-2015, 22:42
waterbott's Avatar
waterbott waterbott is offline
FRC #1683 (Techno Titans)
Team Role: CAD
waterbott is an unknown quantity at this point
Question on designing using #35 Chains
When using websites such as http://www.botlanta.org/converters/d.../sprocket.html, they usually tell you the exact amount of chains or the exact distance that you will hypothetically need between two sprockets. How well does this translate to real life? Should I use the exact amount recommended or should I always give room for error? If so, how much error?
For context, I'm part of the CAD team, but I have little experience with actual robot assembly.
Unread 22-12-2015, 22:57
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Question on designing using #35 Chains
We use the calculators.
do the 1st pass with "chain length calc"
then do a 2nd pass with the "sprocket center dist calc" using the number of integer number of links (rounded up or down) calculated on the 1st pass.
when you assemble the machine, use a good chain tensionerr to draw the chain together.
and you will be good to go.
Ed Barker
Unread 22-12-2015, 23:17
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Remember that chains don't wrap around the pitch circle of sprockets, but instead form a polygon. The difference in circumference of these shapes can change the chain tension as the sprockets rotate (especially with small sprockets), so you always have to leave a bit of slack on the chain (but not too much or you'll jump teeth!).
Also note that the chain will grow with use (as the individual bushings wear). If you have a mounting that doesn't let you adjust tension, you may have to replace chains at some point (no idea how often in an FRC context).
Tsubaki has a good write up on page 15 of their chain guide here: http://www.ustsubaki.com/pdf/iandm_guide.pdf
Unread 22-12-2015, 23:47
cxcad cxcad is offline
cxcad will become famous soon enoughcxcad will become famous soon enough
Hey, I know that team. Just go exact distance and don't bother with tensioners. That's what we did Las year on the drive train and we had no problem
Unread 23-12-2015, 00:01
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
If you are planing to run center to center with out tensioners then check out this thread.
To summarize it, all the parts you use have some play in them. compounded that play will add up to the point where you do not have enough tension. to fix this you can add 0.012" to the center to center distance for #35 chain and 0.018" for #25 chain.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 23-12-2015, 00:52
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
I dug out my 29th edition of Machinery's Handbook and fond that the calculators the OP is utilizing are the equations on page 2553 of said handbook. The calculator isn't for computing an exact distance based on just the pitch but on an old formula for a "tight" chain. You are supposed to use the bottom calculator first then with the decimal output that it gives for "Links" use the top calculator while replacing the decimal value you got for step one with a close integer value. The result of the top calculator is a "true" exact value and you aren't usually supposed to add anything to it.
See attached equation
Edit: Do what Ed said. That's what this calculator was meant for.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 23-12-2015, 05:51
Nate Laverdure's Avatar
FRC #2363
Note that if the sprockets are same size (most of the time in a drivetrain), the eqn simplifies to something quite manageable without the help of an online calculator.
c = P*(L-N)/2
Unread 23-12-2015, 08:03
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Originally Posted by jman4747 View Post
Do what Ed said.
Yep.
Unread 23-12-2015, 11:47
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
c = P*(L-N)/2
What are the variables equal to?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 23-12-2015, 12:41
If you can't see the image Josh posted, here's the text of the relevant paragraph:
Center Distance for a Given Chain Length.--When the distance between the driving and driven sprockets can be varied to suit the length of the chain, this center distance for a tight chain may be determined by the following formula, in which c = center-to-center distance in inches; L = chain length in pitches; P = pitch of chain; N = number of teeth in large sprocket; n = number of teeth in small sprocket.
Nate just simplified it for the case where N = n.
