Go to Post Stop making me think so hard! :D - Chris is me [more]
Unread 22-12-2015, 22:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Rattling Battery?
Has anyone ever had a battery rattle inside? I have a Genesis battery that sounds like it has plastic pellets inside when you shake it, like a musical maraca. What causes this?
Unread 22-12-2015, 23:03
philso philso is offline
FRC #2587
Re: Rattling Battery?
We use several pallets of the Genesis batteries per week in the UPS' we build at work. I have never heard of such a failure mode. The only think I can think of is if the battery was dropped and part of the internal structure that holds the lead plates in place has broken, allowing the lead plates or the broken bits of plastic to rattle around inside.
Unread 23-12-2015, 01:24
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
I'd mark it damaged and recycle it.
Are you absolutely sure the screws/standoffs on the terminals aren't loose?
Unread 23-12-2015, 01:25
Affirmative.
Unread 23-12-2015, 08:26
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Anything that stores energy has the potential of dangerous failure modes. I would call it broken and recycle it. At the very least I would only use it in a static application and not on a moving robot.
Unread 23-12-2015, 11:07
FRC #2587
If the screws or standoffs on the terminals are not loose, then the rattling is internal. Without knowing the internals details of the battery housing, I would do as several of the other people in this thread suggest, send it to recycling. If it is really just an "unimportant" bit of plastic rattling around, you might not have a problem. If that bit of plastic was holding the lead plates in place, the plates might end up shorting out at some point, maybe much later. Such a short can cause the battery to explode and spray acid everywhere. It is just not worth the risk, even if you are on a "low resource" team.
Unread 23-12-2015, 21:07
protoserge's Avatar
The newer rules make batteries much more affordable (~$25-35 shipped for some) so I would find it hard to use the "limited resource team" line.
Unread 23-12-2015, 21:40
While we're on the topic, what is your source for these $25-$35 shipped batteries? Also, given all the various choices in batteries now, is there a clear "best" battery in terms of performance?
Unread 23-12-2015, 22:30
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Do we know for sure that the battery equivalency rule introduced in 2015 is here to stay for 2016?
Unread 23-12-2015, 22:45
protoserge's Avatar
Check out Battery Sharks for the Sigmastek (sp?). 1 battery 2-pack. If you exercise the single battery without shipping option, you can get 4 for $115ish shipped (at least to my zip code).
I don't expect a rule change on this, but buying cheaper 12V batteries should be on all teams' radar for practice and non-competition use. Proper battery management will get at least 4 seasons of use.
There is no real difference between the batteries in capacity or construction. When I was on 836, we ran several brands (MK, Genesys, National, Sigma/Battery Sharks) and they were pretty much identical in all regards using an accepted test procedure for batteries. adciv can probably provide more detail if you require it.
Unread 23-12-2015, 22:54
Knufire Knufire is offline
We've been buying batteries direct from MK Battery for $37.50 shipped.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 23-12-2015, 23:11
protoserge's Avatar
Good to know. Are you using a commercial customer account or just telling them you are a FIRST team?
Unread 23-12-2015, 23:14
Just telling them that we're a FIRST team, looks like they already have the discount set up. Batteries shipped from Anaheim, CA on Tuesday and we received them on Thursday. I just called the number on the bottom of the website.
Unread 24-12-2015, 00:39
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
A bit off the OP -
Many teams have a Battery+Bulbs in their area. See if they are willing to help out - we have been fortunate enough to get a couple of batteries the last number of years for free (no shipping either!).
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 24-12-2015, 11:11
FRC #2587
Yes, the cost of batteries is not that high especially when considering the overall budget. My reference to "low resource" teams speaks more to a perception than reality; i.e. it's not worth it for any team to use a battery that might blow up.
