Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Unread 23-12-2015, 12:52
Re: SmartDashBoard unused objects
In the typical use case, every Network Tables variable gets replicated to the NT server (the robot) and each NT client program (e.g. Dashboard). As long as at least one program is running, a variable will persist indefinitely.
The simplest way to remove an obsolete NT variable is to restart both the robot and the dashboard at the same time, so that neither of them is able to copy the variable to the other.
