Go to Post your chain routing is cute - rachal [more]
Unread 17-12-2015, 09:21
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
kprzewodek is on a distinguished road
Re: 2016 Bosch motor 6004 RA3 194-06
Originally Posted by Bennett548 View Post
Have you tried drilling out the star pattern at 3/8" and broaching a key or a 3/8" hex?
This motor seems like a good choice when you would like to use a hobby servo motor, but need much more power (and have a home position sensor). The biggest issue I see with this motor is that it can't support any load on the output. In FRC we love to abuse our motors and gearboxes by hanging way too much weight on them.
Do you know if these will be available from AndyMark after First Choice is over?
I do have a 3/8" rotary broach and may give that a try. I think it might take too much of the wall out though.
You definitely need to mount this to a completely supported shaft since that acts as the output and second support. If you use the motor to support the shaft then you will most likely have problems.
We decided to offer in limited amounts to get a feel if teams will use them. If there is enough demand then we may be able to consider another order. This is a high volume production motor so it's fairly easy to order more if needed.
Unread 17-12-2015, 11:19
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
We received our first 2 motors yesterday. It looks like the internal star pattern will also accept a 6mm square key (I measured 6.05mm). Oversized key stock (+0/+0.08 tolerance) will probably fit nicely (in stock at McMaster-Carr). I'm also thinking about modifying a 1/4" bore AndyMark hub to accept the 6mm square. Thoughts?
FRC Team 3489 "Category 5"
Unread 17-12-2015, 11:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The reason I suggested putting a wrench on the output of this motor, is because of the speed at which it rotates. There really isn't much use for a shaft, is there?
Unread 17-12-2015, 12:58
kprzewodek's Avatar
As long as what you are driving is fully supported there really isn't much need for a shaft I guess.
Unread 17-12-2015, 13:15
kprzewodek's Avatar
Seems like broaching a 3/8" hex still leaves some meat on the gear. Think I'll try and see how it holds up.
Name:	hex interface.png
Unread 18-12-2015, 10:36
HumblePie's Avatar
AKA: Mista Doug
I laid out one concept for packaging this motor that would fully support the load by sandwiching 2 mounting plates around (1 or 2) piece(s) of 1" square tube. The motor has only one (slotted) mounting hole, so I added a bore to locate on one of the motor bosses and provide some "clocking" of the motor. The drive shaft is a piece of 1/2" hex milled down to a 6mm square on one end. Another option would be to use a 3/8" hex all the way, so I'm curious to see Kevin's results on broaching the motor out to a 3/8" hex.
If there's interest, I'd happily share the CAD file. I got one quote online for waterjet cutting the plates, and it looks like about $100 to make 10 pieces.
File Type: pdf Bosch AHC-2 Motor Assembly_Mounted.PDF (153.9 KB, 191 views)
Unread 18-12-2015, 16:43
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
I am interested in the CAD file. SolidWorks format hopefully.
-T
Unread 18-12-2015, 17:06
kprzewodek's Avatar
That's a nice robust design. I'll experiment over the weekend with broaching a hex and see how it goes.
For a less robust way of doing it I've had success 3D printing a hub inside two plates that you can mount an arm. Simplifies a bit in that you can eliminate bearings.
Unread 19-12-2015, 21:48
D.gimon D.gimon is offline
FRC #5324
D.gimon is an unknown quantity at this point
Hi Kevin,
Seeing as you work for Bosch, is there a source for connectors for last year's Bosch donated spindle motor (PN 6 004 RA3 353-01) which also has Hall signal pins? Looking at the provided PDFs, the motor connectors look very similar.
Can you confirm that the harness will work on both motors?
Thanks,
Dan
Unread 20-12-2015, 01:15
kprzewodek's Avatar
It's the same connector. I can send you some if you PM me your address.
Unread 23-12-2015, 13:43
HumblePie's Avatar
AKA: Mista Doug
Well, let's give it a shot.....
I modified the original plate to better serve as a corner gusset if you should choose to use it that way.
I then saved the Solidworks file as a Parasolid and zipped it. The link (to get around the 5MB limit) is here:
https://app.box.com/s/lcv76duqngz2pukh9qdnlgqz7i5hlqq1
Let me know what you think, and Merry Xmas to all......
Unread 06-01-2016, 08:52
kprzewodek's Avatar
I was able to broach a 3/8" hex and it appears to work quite well. I haven't put the motor through FRC type durability testing yet but so far that seems to be a good option.
Actually the rotary broach that I have goes about 3/4 of the way through the gear however I was able to carefully tap a hex shaft the remaining distance by making sure the gear was supported.
For those on the fence about investing in a linear or rotary broach I would highly recommend as we have used several times over the years. The nice thing about a rotary broach is that the main investment is the tool holder (~$300) and then you can add a wide range of cutting inserts for around $40 a piece.
Unread 19-01-2016, 15:10
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
The square 'neck' of a 1/4" carriage bolt fits.
Unread 19-01-2016, 15:33
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
Post Re: 2016 Bosch motor 6004 RA3 194-06
Hey all, following up on Kevin's behalf here.
(Full disclosure: like Kevin, I am also both a Bosch associate and a longtime member of Bosch-sponsored FRC Team 862.)
Intro
On January 14th, Kevin asked me to spend some time torture testing one of these motors. I was able to jury-rig a fairly decent test setup, and gathered a pretty good chunk of data; at the end of the evening, I explored to see what it would take to break one of these motors altogether. Here's a summary of the test rig:
(click to zoom)
  • Motor output gear broached to 3/8" hex, as described by Kevin
  • Standard 3/8" hex shaft used as output
  • Shaft supported by 3/8" hex bearings on either side of the motor
  • Bearings, in turn, supported by a pair of old 4" VexPro wheels clamped in a vise
  • Motor allowed to float freely in the space between the wheels
  • Appropriate spacing ensured with polypropylene spacers
  • PWM control through custom "electrical test bech" rig
    • Power supplied by fully-charged 2015 battery (swapped halfway through the evening)
    • 2 ft wire from battery to PD board
    • 4 ft 8 inches of wire from Victor to motor
  • Assorted methods used for getting torque off the shaft, described below
Stall Torque Test
(click to zoom)
  • Sought to determine what kind of torque a typical FRC team could reasonably expect to get out of this motor in real-world conditions (bearing friction, side loads, etc.)
  • Plotted real-world output torque at stall against PWM control percentage
  • Motor was driven "clockwise" (as defined on the motor data sheet); resistive force was applied in a "counterclockwise" direction until a stall condition was achieved
  • Used small wrench on output shaft to transfer torque
  • Used spring force gauge to measure output force
  • Multiple data points taken & averaged for each stated value
  • Reported torque = (measured force) x (3.75" lever arm)
    • 3.2 ft-lbs to back-drive without any power applied (not brake mode)
    • 2.0 ft-lbs to stall at 20% pwr
    • 6.6 ft-lbs to stall at 40% pwr
    • 10.2 ft-lbs to stall at 60% pwr
    • 13.3 ft-lbs to stall at 80% pwr
    • 13.6 ft-lbs to stall at 100% pwr
Motor Overheating Test (part 1)
(click to zoom)
  • Used the FRC-standard "anecdotal touch test" to estimate how much abuse it would take to begin to damage one of these motors via overheating
    • This is a fully sealed motor like the CIM and mini-CIM, so it is necessarily designed to be far more tolerant of stalling out than (for example) a Fisher-Price motor
    • This category of motor will still suffer degraded performance if you let them get too hot
    • Rule of thumb:
      • If a motor is too hot to hold, then its performance is temporarily degraded; it needs to cool down before it will regain full performance
      • If even a quick tap of the finger on the surface of the motor is painful, then its performance is permanently degraded
  • Test setup featured adjustable resistance
    • Hex shaft runs through hole drilled in wood block
    • C-clamp to squeeze wood against shaft
    • Torque measured using spring gauge at fixed distance along length of board
    • Wood wore away over time, so the compression needed frequent adjustment
  • Full pwr, no load
    • 5 mins: "Pleasantly warm to the touch"
    • 10 mins: "Very warm"
    • Allowed to cool (10 mins)
  • Full pwr, 4 ft-lb average load
    • 5 mins: "Very warm"
    • 10 mins: "Hot, but not yet painful to touch"
  • Full pwr, 8 ft-lb average load
    • 5 mins: "Hot, but not yet painful"
    • 10 mins: Test aborted, resistance board fully eaten through
    • Allowed to cool (15 mins)
(part 2)
(click to zoom)
  • With the adjustable-friction rig destroyed, any further tests could only be achieved with a longer lever arm
  • No suitable supplies were readily available, so it was decided to skip straight ahead to the stall condition
  • A large wrench was fitted to the shaft, long enough for the edges of the vise to act as end stops for the motor's rotation
  • Motor was alternately driven "clockwise" and "counterclockwise" (as defined on the motor data sheet) at 100% power
    • Approximately 90 degrees of output shaft rotation before the end stops were reached
    • Whenever an end stop was reached, the motor was allowed to stall at full power for three seconds
    • After stalling for three seconds, the direction was immediately reversed
    • This process was repeated for 2 minutes and 30 seconds
  • The "anecdotal touch test" was performed repeatedly upon the conclusion of this test sequence
    • A motor in stall tends to build up heat in its core faster than it can be transferred to the outside shell
    • First test, immediately upon the conclusion of the 2:30 test sequence: "Hot, but not yet painful"
    • Peak temperature of external shell of motor: "Just barely too hot to hold"
  • Once the motor was allowed to cool back down, no difference was noted in the motor's performance vs. before the overheating test was performed
Death Test
(No picture for this one yet; sorry!)
  • With all of that done, it was time for something a bit more... Aggressive.
  • The large wrench from the previous configuration was left in place
  • The spring force gauge was brought back and used to back-drive the unpowered motor
    • The motor was successfully back-driven in both directions with up to 21 ft-lbs of torque
    • No signs of damage thus far
  • This clearly wasn't doing the trick, so low power was applied to the motor causing it to rotate "counterclockwise" (as defined on the motor data sheet)
    • Using the large wrench and force gauge again, an attempt was made to back-drive the motor again
    • No back-driving was possible against the powered motor
    • A peak of 27 ft-lbs was reached before something started snapping
      • With each snap, the output shaft rotated a short distance opposite to the motor's rotation
      • No loose teeth could be heard jostling around within the gearbox, however, and the motor ran perfectly normal (even at stall!) thereafter
      • Thus, it is reasonable to conclude that the observed failure mode was the result of the deformation of teeth within the motor's attached gearbox
      • Presumably, continued operation in the 20+ ft-lb range would eventually cause performance to degrade below the range of normal operation
    • Upon investigation, the hex shaft had rotated approximately 20 degrees relative to the hex broached output gear before the failure occurred
      • It is therefore possible that the resulting deformation of the output gear may have played a role in the observed failure
      • The use of the stock 8-pointed spline shaft may therefore stave off failure to an even higher torque level, but that is just speculation
  • I hope to crack open the motor in question and confirm these hypotheses, but right now we're in the middle of building a robot!
Conclusion
This motor could handle a stall condition with the best of 'em, and withstood 2x its own stall torque before giving way. Even when it did "break", it still continued operating normally for applied torques up to and including its stall torque.
All in all, I have no reservations at all about recommending this motor for use in any application that warrants a motor with torque/speed ratings in this range:
  • Deploying a collector
  • Rotating a turret
  • Winding up a catapult
  • Manipulating the Portcullis, Drawbridge, Cheval de Frise, and/or Sally Port
  • Et cetera
Unread 19-01-2016, 15:43
MrForbes's Avatar
AKA: Jim
thanks!
