Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-12-2015, 15:18
DrWaSaBi's Avatar
DrWaSaBi DrWaSaBi is offline
FRC #1711 (The RAPTORS)
Rookie Year: 2015
DrWaSaBi is an unknown quantity at this point
Re: Using an Andymark Arduino on a robot.
Unless it's the number of ports you need, or your loading some LED library. I would think you could drive them right from the RoboRio. Most LED strips I've seen just take some sort of pwm. I would think you could drive them direct.
Dr. W
Unread 23-12-2015, 15:50
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
This may help:
http://www.chiefdelphi.com/forums/sh...hreadid=131776
Unread 26-12-2015, 12:39
REVving up for a new season
FRC #2848 (All-sparks)
I think you should check out the RIOdunio. It is a custom arduino designed to talk to the roborio through the mxp port. You mention controlling LEd's we have a special breakout for neopixle strips on every RIOduino. They are also available from AndyMark.
http://www.andymark.com/product-p/am-2996.htm
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
