Has anyone made a swerve drive that's run on one motor?
Had a team made a swerve drive where only one motor is used to rotate the wheels? I feel this design could maybe save weight as well as save on power consumption/CPU usage. If you had 5 motors instead of 8 then it could draw less power theoretically.
Re: Has anyone made a swerve drive that's run on one motor?
Many times. This style is often referred to as a crab drive.
It is primarily used to make programming and driving more straightforward. However, it also takes away a lot of the versatility of a swerve drive, removing the ability to perform maneuvers which require wheels facing different directions. Additionally, the motor power required to steer four modules is not trivial, and a rather torquey motor is necessary. |
do you mean rotate the wheels, as in steering them? or as in driving them?
Took me a bit, but here is a 2009 robot from 1405 that does this.
A few years ago FRC11 did steer a swerve drive with 2 steering motors. It did not end well but it did get a programming award trying to sort out the 'Tazmanian Devil' issues with steering and synchronizing 2 position targeted PID loops. It also pushed the limits of what we could pull off with Java on the cRIO because there were many motion control issues that had to be contended with. Given the 6 week build window there would have to be a great reason to engage in these acrobatics instead of a simple piece of chain and one motor. Last edited by techhelpbb : 23-12-2015 at 16:46. |
Crab drives use one motor to steer. I have never heard of a swerve drive module that uses the same motor to steer and turn the wheel. |
#7
Robonauts have a great video showing off some of the points discussed here.
https://www.youtube.com/watch?v=CAJBC-DDL9w (2008) They spoke about the drive train in 2009. The fundamental problem with steering all four wheels together is simply aligning the wheels so they all point the same direction to begin with. This is why their pods are designed the way they are, and why the 221 product is based upon their design. |
#9
A majority of the competitive swerve drive in the past couple of years have had one steering motor per module. Namely teams like 1717, 368, 16, 2471, and many more use it to give them more versatility in the ways they can position their wheels.
#10
I've heard of a theoretical 3 sim swerve.
#11
#12
![]() This is how I imagine everyone in this thread responding to OP. |
#13
...because, strictly, three is not equal to four. And the little monster had two FPs as well, bringing its total propulsion power nearer to that of six CIMs. Underweight and overpowered -- the thing could fly.
![]() Last edited by Richard Wallace : 24-12-2015 at 20:13. |
#14
That is the core issue. If you confine your swerve build to just the 6 week build season, even if you buy the modules (which by definition means you just bought someone else's development time), will you be able to achieve good control? The teams I have seen achieve this devoted good time to this task and the reward was fully exploiting it. They often did this work over several seasons or with extensive off season exploration. Outside that... I've thought this over quite a bit. As the OP mentions the cost of 4 CIM motors/speed controls to drive steering indepently is pretty high. 8 CIMs risks a good hunk of battery power in addition to driving weight. One could counter that you only use the steering CIMs when you steer but is that not the goal? Assuming one tames the power required or uses a smaller motor with sufficient gearing to steer to overcome this.... Is this really a mere 6 week task to gain a degree of freedom that as others have pointed out risks reducing your ability to drive straight? If I could do swerve in FRC again (my team's experience was so bad they always opt out) I would not do it with the expectation it will be fully polished in just 6 weeks. I could not justify the risk even if I know the task is doable in the general sense. I can easily see doing swerve outside of FRC where I have my choice of hardware and controls. Can anyone provide examples of teams that jumped into swerves cold in a 6 week build season and fully exploited it? I am honestly curious my experience is limited to the northeast US. I would be very curious if they bought the modules or borrowed their code to make it work in that timeframe. I can accept it is possible but would like to understand the details. Last edited by techhelpbb : 25-12-2015 at 05:12. |
#15
