Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 25-03-2003, 14:49
David.Cook's Avatar
David.Cook David.Cook is offline
#0384 (Sparky)
David.Cook is an unknown quantity at this point
Send a message via Yahoo to David.Cook
Redukes has the correct answer here.
We experienced the same problem, which you would only encounter during the practice matches.
Auton mode works the first time, because the RC is in a fresh reset state at the start. However, the field does not reset your robot controller between the two practice runs, so if you counted your auton operation to 400 steps, the step counter is still at 400, and nothing will happen. You can solve this by simply pressing the robot reset switch between the two test runs - or cycling power.
We had the same problem at NASA/VCU during our first two runs - we were going crazy trying to figure out why one of our auton modes wouldn't work, but it had nothing to do with our coding.
BTW, there is an elegant fix for this in code. Once Auton mode is false - reset you timers, counters, whatever. This makes the robot essentially self-reset the auton variables once driver control is initiated.
Be unrestrained as the wind...
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
