Go to Post Building things from scratch builds character. - davidthefat [more]
Unread 24-12-2015, 20:42
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Rattling Battery?
While I don't see there being a battery that is clearly better than others.
There are batteries which would be more suited to the abuse and the high current draw that FRC batteries typically face.
Some Battery manufactures supply intended use information with their batteries. I have found two different types of Panasonic Batteries online, both with similar capacity. The difference lies in their intended use. One battery use statement says "UPS, Security, Alarm, Instrument, Test Equipment, Medical Equipment;This model should be used for standby use only". Where as the other battery says "battery suitable for continuous cyclic usage such as golf buggies & mobility aids/motorised scooters."
Now, the difficult thing to consider is which of these fits FRC best. Typically batteries are charged and then not used for periods of time, then when it comes to events they are rapidly discharged and then recharged continuously. Would a battery intended for a UPS or a battery intended for something like a motorised scouter be superior?
Coming back to the actual intended thread topic, the Rattling Battery seems really strange. I would recommend recycling or disposing of it, it's just not worth the risk.
Unread 28-12-2015, 07:30
Dave,
Generally there is nothing good about loose particles inside the battery. It is possible that someone dropped something on the cover over the pressure relief valves. Small pieces of plastic may have broken off.
It is also very likely, some of the internal plastic between cells has broken loose. If this is an AGM battery, there may not be any immediate danger. I would recycle before something occurs.
The pressure relief seals at the top of each cell I have seen are mostly rubber and would not rattle if they came loose.
Does the rattle appear restricted to the valve cover?
Unread 28-12-2015, 08:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The difference between these two cases is the speed of discharge and the number of deep cycles the battery will run. FRC matches the scooter/golf cart model (motors/high peak output current, hundreds of cycles over a lifetime) much better than security/UPS (more "slow and steady" discharge when used, probably a dozen cycles per lifetime).
And yes, I concur that the rattling battery should be retired and recycled.
Unread 28-12-2015, 11:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The rattling was much deeper inside, closer to the bottom than the top. I took it in for recycling.
Unread 28-12-2015, 11:29
Allastair,
Many of the UPS devices we have here use the same batteries that we use in FRC. Interestingly, they also have SB50 (not red) connectors on them.
Unread 15-01-2016, 12:07
dharg99's Avatar
dharg99 dharg99 is offline
FRC #4633
dharg99 is an unknown quantity at this point
Could the rattling have just been when driving or was this all the time?
My team thought we had a bad battery too... Found out it was the battery edge vibrating on a piece of wood.
#4633Lyfe
Unread 15-01-2016, 12:33
It was definitely internal. We've since purchased new batteries.
Unread 15-01-2016, 23:31
dharg99's Avatar
FRC #4633
That sucks, good to hear you replaced them
#4633Lyfe
Unread 16-01-2016, 00:17
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by Knufire View Post
Just telling them that we're a FIRST team, looks like they already have the discount set up. Batteries shipped from Anaheim, CA on Tuesday and we received them on Thursday. I just called the number on the bottom of the website.
I've been using a little place called amazon. for 35ish.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
