Go to Post Wow... no duct tape? - Stormnnormn [more]
Unread 24-12-2015, 22:30
aurangzeb aurangzeb is offline
aurangzeb is an unknown quantity at this point
Red face Please help
So I want to build a robot powered by an arduino uno rev 3 for my science fair project. I want to compare tank control and joystick control. I will do this by building a race track and time how fast each type of control completes the race. My problem is that I don't know how to connect a controller to it. I have seen that I can control the robot with usb host by using a Bluetooth dongle to connect a PS3 controller to it. Also I've heard that you can control the robot over wifi. I'm a beginner in robotics and have little experience with coding. The science fair is in a month and I would appreciate it a lot if anyone could help.
This is the link to the video I saw: http://youtu.be/q3vXTX6Qe54
Unread 25-12-2015, 01:42
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Please help
Did you try following the steps in the video?
Unread 25-12-2015, 04:06
Re: Please help
I have not bought any of the parts yet because I'm not sure if every usb host works with a Bluetooth dongle. Also I'm not confident in building the one he linked in the video. I found one on Amazon and I don't know if it is going to work or not, but it looks the same. I found a Bluetooth dongle compatible with the program located on his blog. All I need to know is that Bluetooth dongles are compatible with any usb host. Sorry I was not clear in the beginning.
The blog:
https://barrettsprojects.wordpress.c...demonstration/
The usb host I found:
http://www.amazon.com/gp/product/B00...A1A5FQE7R5RISB
Unread 25-12-2015, 12:26
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Re: Please help
Every USB host should work the same way. Amazon even says that the bluetooth dongle is frequently bought with the shield.
Unread 25-12-2015, 14:03
Re: Please help
Ok, thank you so much that's all I needed to know
