Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 25-12-2015, 00:06
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Snap Action Breaker Alternative
I'm working on a non-FRC robot using the old (2009-2014) PDB. The normal competition legal 20A/30A/40A snap action breakers cost between $5 - $8 online, so I'm looking for cheaper alternatives.
Can anyone refer me to a cheap, equivalently sized fuse they've used? I'm looking at MAXI style fuses, so would products like this or this fit in the PDB?
2012 - 2015 • Team 2601
Unread 25-12-2015, 08:28
Re: Snap Action Breaker Alternative
Or email CTRE for advice on an alternative.
Unread 25-12-2015, 08:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Perhaps the Maxi fuses do fit the 40 amp slots, and ATO fuses fit the 20/30 a slots?
I don't have any Maxi fuses handy, to check...but that's what it looks like to me.
Unread 25-12-2015, 08:55
Yea, I take back what I said about Maxi, they do look like a fit.
They match the dimensions of the 40a slot in the PDB.
I was mixing them up with the ATO fuses.
P.S.
Found supporting evidence in a snap action 40a breaker spec sheet quote
"Direct replacement for "MAXI" automotive style fuses"
So the question becomes how close to the 40a fuse maximum does your non-FRC robot run?
If it draws less than no problem. If it regularly draws over 40a, in a starting stall condition for instance, then it'll be a question of how often do they need replacement before the $6 breaker would be the better bargain.
Name:	MAXI Fuse Dimensions.png
ID:	19611  Click image for larger version
Name:	MX5 dimensions.png
Unread 25-12-2015, 14:18
On a related note, I've been on a hunt for the (really) old MAXI blocks that we used to use on the robots, or an equivalent. I'm talking those gold-plated ones with a clear cover--anybody remember those? KOP list from back that far doesn't seem to have the part number or anything similar.
Unread 25-12-2015, 15:39
REVving up for a new season
FRC #2848 (All-sparks)
If you just do a google search for Maxi fuse block, you will find equivalent ones. The ones we used to get were mainly used for car audio.
http://www.amazon.com/Stinger-SFPD4M...dp/B00Q50CSB8/
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 25-12-2015, 16:29
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Or visit the local car stereo shop or bestbuy. Best Buy will have them as part of an amplifier install kit.
Unread 25-12-2015, 23:31
NWChen's Avatar
Alum
Thanks everyone for your help.
Unread 25-12-2015, 23:58
Based on some really quick research, a slow blow fuse will react slower then the snap action circuit breakers FRC uses, while normal blow fuses will react similarly.
Unread 28-12-2015, 07:43
Guys,
The snap action breakers we use will sustain a 600% overload for a second or two and 300% for a while longer. When you are running CIMs the stall(start) current is 131 amps. If you use normal fuses, they will open with high current motors. While the fuses do have a spec that provides for currents in excess of their rated values, they do not survive three times their current ratings for very long and they are not repairable.
Bussman sheets can be found here...http://www.cooperindustries.com/cont...S_2049_MAX.pdf
I would suspect any house branded fuses like DB (linked above).
Unread 28-12-2015, 08:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Guys,
I agree that the breakers are better all around. If you insist on fuses with large motors, be sure to ramp your voltage up to avoid that high inrush current. Of course, if the motor gets stuck, you will still draw that 131A when you get to full throttle. I would suggest monitoring the current to avoid this condition, but current-monitoring modules cost more than breakers.
Unread 28-12-2015, 12:10
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We still have one sitting around. If you PM me an address, I'll talk to the mentors and see if we can ship it out to you!
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-12-2015, 17:02
Thanks for the offer, but I'm pretty sure that wouldn't be feasible--this is for a non-FRC project, so we'd prefer to be able to track everything through our (more) standard sources. Though if it has a part number, that would help in tracking down similar products...
Unread 28-12-2015, 18:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Go back a few posts, and you can find a link!
We used a Stinger maxi block for early iterations of our air cannon with the FRC-style snap breakers. The cannon outgrew four circuits, so we're now using an old PDB.
