Go to Post Definitely read through ALL the documentation, and if you still have questions, ask. - Joe Ross [more]
View Poll Results: Favorite Motor Controller
Talon SRX 58 49.57%
Victor SP 29 24.79%
Jaguar 4 3.42%
Spark 13 11.11%
SD540 13 11.11%
Voters: 117. You may not vote on this poll
Unread 23-12-2015, 11:11
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Re: Motor Controllers
Talon SRX are my favorite. Unless you need the advanced features of the Talon the Victor SP makes more economic sense. I will wait to pass judgement on the new 2016 controllers when they prove their durability.
Other than size the jaguars don't deserve their bad reputation. We found them reliable when connected correct and not filled with metal shavings.
Unread 23-12-2015, 11:21
aldaeron aldaeron is online now
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Originally Posted by JPBlacksmiths View Post
So this is a question that I have had for a few years now, and never really gotten a good answer to it:
Which motor controller is the best for which situation? Meaning is there specific applications were one controller is better then the other, or is there just one motor controller which is the best, period?
This question has resurfaced for me especially with the creation of the new motor controllers such as the spark.
Thanks,
JP
Co-Captain Team 806
Getting back on topic to answer OP's questions...
As with most things in engineering design, the answer here is "it depends". In my mind there are three key features to look at: cost, capability and reliability. I am only going to focus on the controllers you can buy going forward (Talon SRX, Victor SP, REV Spark, MS SD540). Since you can't get spares for other controllers easily I would stay away from or use them sparingly (and with LOTS of spares ready just in case).
Talon SRX at $90 is the most capable, but also the most expensive.
Capability: Talon SRX allow use of a Controller Area Network (CAN) bus. The other option is Pulse Width Modulation (PWM). With a bus you get two way communication between controllers and the RoboRio.
Also, the Talon SRX has an input data port that allows you to do some routine control calculations directly on the controller instead of using the RoboRio. You can hookup small breakout boards to the data port and do a number of control loops. Some examples are that you can hookup an encoder to a shaft and thru the data port and tell the motor controller to drive forward until the encoder has reached 1000 ticks and then stop. Another example is that you can tell the motor controller to drive forward until the upper limit switch on your elevator is tripped and then stop. With PWM the RoboRio has to check all these sensors and issue the commands to stop. Since the RoboRio is doing a lot of calculations it may be slower to respond (by some number of milliseconds) to when the switch is tripped on your elevator. The Talon SRX offloads these mundane control calculations from the RoboRio.
Cost: You pay for all these nice features (CAN bus chip, extra connector for data port inputs). Over a whole bot this extra cost can add up.
Reliability: Last season the Talon SRX performed well with few (if any) failures. Since there was no defense and therefore few long duration high current pushing matches, there could be an argument made that some more testing is needed under these extreme conditions. Most people would agree it is a solid and FRC tested design. It also has a very small foot print and a sealed aluminum enclosure. This prevents debris from getting in and shorting out electrical components (a problem with older controllers). Aluminum is a great heat conductor and allows the heat generated by the controller to be moved away from the electronic chips without the need for a separate fan.
Victor SP at $60 is a robust, but basic controller.
Capability: Talon SP is a simple Pulse Width Modulation (PWM) driven controller. No fancy data inputs, just the ability to set the speed between 0 and 100%.
Cost: You pay for a smaller form factor and an aluminum case. More expensive than other PWM controllers and does not have data inputs.
Reliability: Same as Talon SRX. Most would agree it is a proven, dependable controller for FRC.
REV Spark at $45 is a new low cost controller with some nice looking features.
Capability: REV Spark is a simple Pulse Width Modulation (PWM) driven controller. You can set the speed between 0 and 100%. It also has a basic input data port that will allow you to directly wire in a set of limit switches to stop it. These limit switches are great for an elevator or a rotary arm with a top/bottom limit switch. No fancy encoder or other control capabilities. Pretty impressive for such a low cost device.
Cost: Cheapest one on the market for FRC right now.
Reliability: This is brand new this year. Preliminary test data looks positive. It has a plastic case, which will not transfer heat as well as aluminum. It claims not to need fan cooling, which is being tested in lab conditions (I believe results release soon). Obviously the real test is to see it during the season. Be cautious about switching to a new controller with limited testing unless you can afford to replace the controllers. It is a bit larger than the Victor SP and Talon SRX. For the price it looks promising.
MS SD540 at $50 is a new low cost controller with some nice looking features.
The SD540 implements many of the same features that the REV Spark does, albeit in a different layout. There are some concerns about the design choices made for the SD540 that are detailed in another thread. Same overall story - low cost plastic body controller with PWM input and limit switch control build in. Untested.
Hope that helps. PM me for more detail (I glossed some of the nitty gritty details)
-matto-
Unread 23-12-2015, 11:22
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by GeeTwo View Post
However, this exception was not included for the withholding allowance; if you wanted a pre-terminated controller as a spare part, it needed to be included in the withholding allowance.
I wonder why they made that distinction. Is it too much of an advantage to have a drop-in replacement motor or controller ready to go?
I could see the first task for a student in the pit being to crimp some connectors onto a set of spare motors and controllers, ready to go.
In fact... *writes that down*
As for the poll, I voted for Talon SRX since it seems to offer quite a lot of potential advantages for the fairly minimal extra cost. Virtually every one of our robot failures last year, both on our practice field and unfortunately during our first regional, was some combination of our software addressing the incorrect PWM or DIO, the encoder wired incorrectly, read incorrectly, software values set/reset incorrectly, motors trying to run the forklift past the edge (e.g. we didn't have time to wire in a hard limit switch), etc. If we thought to use the limit switch and encoder functionality in the Talon SRX, and communicate over CAN instead of PWMs and DIOs, our code (and failure modes) could have been much simpler.
Unread 26-12-2015, 17:14
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the rough
Originally Posted by Michael Blake View Post
Wondering why Victor 884/888 was left out of voting yet Jaguar was included?
--Michael Blake
simply because this is all of the current motor controllers, nothing as far as I know has been made to replace the jaguar.
Unread 26-12-2015, 17:57
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Though they don't have the same name (because they're made by different companies IIRC) the Talon SRX effectively replaces the Jaguar. It does the same PID control, limit switches, etc with better CAN support. I wouldn't buy Jaguars new even if they still were for sale.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 26-12-2015, 18:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by SoftwareBug2.0 View Post
There's no reason for a Jaguar to be anyone's favorite
Jaguar is my least favorite, but I couldn't let that challenge pass. I came up with three reasons for Jag to be someone's favorite (I left out nostalgia and thinks like being the biggest, heaviest, and having the smallest continuous current capability, and having a nonstandard PWM response):
  • Supply Voltage: works down to 5.5V and up to 30V, Tied for first best at both ends with SPARK.
  • Aesthetics: The jaguar case is a work of art compared to the boxes with fans (Victor 884 and 888) and the boxes without fans (the others).
  • You can control a Jaguar with RS-232. I can contrive of a few applications where this would be useful, like controlling from an old PC.
Edit:
Originally Posted by MrBasse View Post
Don't forget the fact that the flames that poured out of Jags were very entertaining for the kids!
Now I feel cheated; I've smelled and seen plenty of blue smoke, but never seen flames .
Unread 26-12-2015, 19:02
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
PWM from parallel port and they all can be controlled by an old PC
I am waiting for the single IC speed control module. It is coming. Just a chip with bolts on the top like an IGBT and an electrically isolated metal plate on the bottom.
Unread 26-12-2015, 20:02
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I'd never heard of this, and a bit of web searches about the old centronics port leads me to think that the PC-side hardware was not made to support PWM; whether it would be possible to hack it with a tight loop that shut down the PC for any other purposes is probably hardware dependent. Has someone actually done this (using passive components, which was my meaning)?
Heat dissipation is a big issue here, unless you're talking about replacing the spike rather than a speed controller. The amount of electrical isolation demanded by FIRST is also a steep challenge. I expect brush-less motors and controllers to be FRC legal before single-chip brushed motor speed controllers. I'm not holding my breath on either one.
Unread 26-12-2015, 21:57
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 27-12-2015, 00:40
techhelpbb's Avatar
Ether did PWM 'bit banging' of the handshake wires on a serial port:
http://www.chiefdelphi.com/forums/sh...52&postcount=1
I used to play .mod MIDI files on a parallel port justing just a resistor ladder and a capacitor to couple still have that stuff somewhere and that was on a Intel 80386 DX 16MHz. That's complex analog audio at up to 15kHz. So yes I am sure if I sat there with some C code I could control several FRC PWM speed control on FreeDOS. I would not attempt this in on any Windows NT kernel because you need a kernel mode driver. It is likely possible on BSD/Linux.
DOS runs in real mode. You will not block the timer interrupts or other interrupts doing this. I used to run this silly trick even with EMM386 running and Windows 3.11.
HighTreason take it away old school...
https://youtu.be/4KUdBgg8Oe4
Then again....I still maintain Commodore 64 code I wrote....so I am pretty dusty.
The heat dissipation of any single part in an FRC robot is no where near the heat dissipation of the big IGBT we used to charge Navy submarine batteries with this big charger we built. The base of the integrated package is metal and you torque the package to the heatsink plate with either a coupling patch or compound. One of my cohorts left a databook on a board during a test...let's just say we will not read that databook again .
The issue is merely distributing the heat away from the parts that get hot. Either make them more efficient or make the removal of heat more efficient. Same reason we could fill power supplies up with canola oil....as long as you do not let the pressure build or reach the flash point it will not conduct but it will make the heat distribute around (do not try at home kids). That silly trick allowed almost double the wattage from a power supply. By the way - TDI in Hackettstown, NJ was selling a design like this actively before AstroDyne bought them.
There was a time when people argued no FRC speed control would last without a fan either. Power MOSFETs keep getting better and better. Lower the switching losses and on state resistance enough and the heat dissipation will follow. Just please do not do it with silver in the semiconductor die (let's just say it makes the power semiconductors go bad eventually and leave it there).
Unread 27-12-2015, 01:21
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Ether did PWM 'bit banging' of the handshake wires on a serial port.....
I'll accept your word and Ether's.
The heat dissipation of any single part in an FRC robot...
I think you made my point better than I did.
Unread 27-12-2015, 01:34
techhelpbb's Avatar
The actual problem is not actually the heat:
It is the whether doing that tight integration is financially workable given the market.
A massive power transistor has a much wider market than FRC and a much higher price point.
However with all the interest in drones and places like SuperDroidRobotics selling kits that are FRC size like for plows and snowblowers...the market is growing.
I suspect back in the day when audio receivers were individual power transistors many people also thought they would not be surpassed by integrated modules. Odds are if you tear down a retail home reciever you find modules in plenty of them.
Unread 27-12-2015, 10:41
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Thanks,
JP
Co-Captain Team 806
Well the new Talon SRX is best if you can take advantage of what it offers over the Victor SP which is control by CAN and direct sensor feedback (encoders). This is why it costs more. If you can't take advantage of that then the Victor SP is better because it is cheaper and offers the same size advantages as the SRX. Hope that helps.
Also, Jag - ewww - don't use that...
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 28-12-2015, 09:00
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Part of my own evaluation of the SPARK was having a look inside. While much of the case is plastic, the SPARK label in the center is covering a heavy c-channel shaped slug of aluminum with heat transfer pads to encourage cooling of the 4 MOSFETs and 3 electrolytic capacitors under it. My gut feel (with nothing but experience to back it up) tells me this device will survive a 2-minute pushing match just fine.
The footprint is close, but not identical to that of the Talon SR.
Unread 28-12-2015, 11:38
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by DaveL View Post
Would like to here from others on how they connect the Talon green and yellow CAN wires together. Vex sells a nice device but it's expensive and it takes up a lot of room.
Check these out.
We used these last season. They're toolless, and we've never had a problem with them falling off or breaking. They're designed for larger wires than the CAN wires, but they still work fine. They're a little bulky, but not big enough to cause problems.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
